M caliper identification
Need help with dating these M calipers. If you can ID them please assist. TIA
Kevin 84 911 Carrera 71 911E Vintage Race Car 25 Ford Explorer ST 20 Subaru Crosstrek |
The center and right could have come from about 1969 through about 1974.
No idea on the left one.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
PMB Performance
The far left caliper is a Carrera rear caliper with a piece of toilet paper in it's inlet
If you only have one I might have a mate.I'd need more detail on the front gussets on the others and it would help to see the tops but, Dave is pretty much spot on with the date range of those. Garden variety front M-Calipers.
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
PMB Performance
Ooooooooops, sorry, just noticed the far right one has a fluid inlet on it's end. That's a rear M-Caliper (70-83). That being the case, the center one looks proportionate and is probably an early 914 front caliper (70-72.8).
Turn it over and please tell me more about the fasteners. M7 fasteners with a cap head (on the middle caliper) means it's an early 914 front caliper. They are cast from the same mold as the far right rear m-caliper but do not have spacers and have a larger 42mm piston (38mm on the far right one). If it has M7 11mm hex head bolt with dual bleeders, it's a later model 914 front caliper (73-76). Probably has VW cast into it somewhere as well. The Carrera rear caliper is 84-88. Hope that helps.
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com Last edited by Eric_Shea; 01-27-2011 at 07:07 PM.. |
