Cam line hollow bolt
sort of searched without finding the specific answer so I thought I'd ask.
Is this thing called a hollow bolt and sometimes referred to as a banjo bolt?
Changed the right side cam oil line and wondered about that hollow bolt.
Did this with the a/c bracket still on the car what a PITA!
Ran the car for about a minute and didn't notice any leaking.
How do you know you have the bolt (holes) aligned correctly or do you just tighten it down?
Don't you somehow have to align one hole in the bolt were the oil line enters that ring?
How do the holes in the bolt do their job?
thanks.
Old 12-12-2010, 12:21 PM
Crusty Conservative
silverc4s's Avatar
It will work through the entire 180 deg of alignment, due to a curved open area within the banjo fitting.
Nope, see above
The oil comes up through the hollow bolt, then exits those holes and into the banjo fitting. Make sure you have a washer on either side of the banjo fitting
thanks.
Hope that answers your questions...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 12-12-2010, 12:41 PM
Band.
The 'banjo' is round like a tire; you don't have to line up the 'holes', oil will flow anyway.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-12-2010, 12:42 PM
Thanks for the quick replies!
I did place new washers on both sides of the bolt.
Old 12-12-2010, 12:50 PM
