newby
Hi Guys - Steering Wheel Question ..
I have an 89 930 and I've just done the old high beam low beam fix and when I've gone to put everything back together I've noticed this wire hanging down with no obvious point of dettachment - can anyone tell me where it should be ??
It's the loose wire at the bottom .. Cheers .. Ben
1989 Black 930 3.3 964 Turbo Motor 5 Speed Ben Clark Photography Website: http://www.benclarkphotography.com.au See our latest work:http://www.benclarkphotography.com.au/blog Associate member of the AIPP - Aust Inst of Professional Photographers |
SC Ray
Sorry to high-jack - what is the "old high beam low beam trick" - the suspense is killing me!!
Thanks, Ray |
winter
that might be for your horn, attaches to the back of the white plastic piece at the top of your photo.
if you ground it to anything metal when the ignition key is "on" and your horn sounds, the proof is in the honk! Good luck!
Tom '76 Targa |
76 911S Targa
That's the ground tab for the horn. It is held in place by a small screw to the lower right in the metal plate below the steering shaft. The plastic shrouding is held by the same screws so have fun holding the metal ground tab in place while aligning the plastic shroud and then threading the screw through both.
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
newby
newby
All fixed now thanks to my fellow Pelicans .. ! As a reward here is a pic of my car !
I have to take some "proper" photos soon ! This is an Iphone pic ..
