-   -   rust behind battery? (http://forums.pelicanparts.com/porsche-911-technical-forum/580130-rust-behind-battery.html)
DucktailCTR 12-13-2010 01:37 PM
found a pretty bad rust spot behind the battery... cut it out and weld? suggestions?
Rot 911 12-13-2010 02:20 PM
Year of car and pictures would help. Was it rust from battery acid or rust from crud piling up on the inside of the fender and rusting from the outside in?
tharbert 12-13-2010 02:29 PM
Clean it up with a wire brush back to the edges of good paint. If it's just spot rust, cleaning and priming may be fine. Be sure to neutralize any remaining acid. If you have a hole, post pictures and see what the experts say.
DucktailCTR 12-13-2010 02:48 PM
http://i32.photobucket.com/albums/d1...01213-1423.jpg
1976 from the inside
Rot 911 12-13-2010 03:00 PM
You sure that is from the inside out? On at least the Carrera, there is a ledge up in that spot in the wheel wheel that collects dirt, which holds water, which creates rust. Either way you are looking at removing the fender and patching the inner fender. Not overly complicated, but is labor intensive.
ossiblue 12-13-2010 03:08 PM
From what little I can see, it looks fairly deep. Next step, clean it all away to shiny metal and post another picture.
DucktailCTR 12-13-2010 07:23 PM
took out some more stuff andIm beginning to think of replacing the front end. how difficult does everyone think replacing the front frame with a tube frame would be?
500_19B 12-13-2010 07:33 PM
Hmmm... Hard to see for sure in that photo... it does look like it is higher up which suggests rust from crud built up on the topside of the bumper shock support which is in that area (as suggested above). A poster here, I think named Sailchief did a nice writeup on this.
The other major rust issue near the battery is suspension pan rot, caused by battery acid that leaked out at one time and was not properly dealt with. More common than many realize on these cars I believe. I had this problem and you can get a bit on an idea of how it went for me here:
Battery-area surprise! - Rennlist Discussion Forums
In either case, I think that you will find that the necessary replacement sheet metal is pretty reasonable and will be simpler and cheaper than doing tube frame front end.
DucktailCTR 12-14-2010 01:26 PM
what gauge steel would you suggest using for the sides?
brads911sc 12-14-2010 01:54 PM
I wouldnt worry about the guage of steel just yet. You need to get it all cleaned/cut out and then determine what you need....
DaddyGlenn 12-14-2010 02:07 PM
Recent experience makes me think you might have rusted shock mounts, like me.
http://forums.pelicanparts.com/uploa...1292364389.jpg
From my thread here.
500_19B 12-14-2010 02:21 PM
Yeah, that's a nice write-up (and repair) too!
