wrong distributor?
does anyone know the part number for the correct, (bosch) distributor for a 73, 911T w CIS and CDI?:confused:
Mine is 0-231-169-008.
The Porsche 72/73 Specs booklet, page 97, lists a Bosch 0.231.169.008 distributor for the 1973 911T model only, as Gogar says his is. It doesn't mention a difference for fuel systems, as '73 T can be either MFI or CIS, although it does list a Marelli alternative. I have a good Bosch 008 distributor available, if needed.
Here's the Specs booklet page:
http://forums.pelicanparts.com/uploa...1292300827.jpg http://forums.pelicanparts.com/uploa...1292300875.jpg |
FYI 003,004, and 005 are the MFI '72-73 distributors, with different rev limiting rotors.
008, 009, and 010 are the CIS with different advance curve (i'm guessing about that) but made for CIS, with different rev limiting rotors. I found out what I know about it looking at old Early S Man threads and here's where that happened: http://forums.pelicanparts.com/porsche-911-technical-forum/574407-pertronix-008-distributor-again.html |
| All times are GMT -8. The time now is 03:15 AM. |
