Clunk from the rear when lift off/reverse/start/u-turn
hello , I'm sorry for the noob question but this clunk is driving me insane !!!
the sound appears when going in reverse or starting from full stop and it appears when I lift off the gas pedal or doing a right 90 degree turn .
I made 2 vids of the noise , I think it could be the CV , but there's no play at all
http://www.youtube.com/watch?v=ZRE8TiVRxzk
YouTube - E36 driveshat U Joint
thanks again for the much appreciated help !
Old 12-16-2010, 04:20 AM
CV joints generally make a sound like a horse's hoof on pavement. also can be a single snap when doing what you describe. my 930 just started that, so it's time to get gooey.
206 637 4071
Old 12-16-2010, 05:27 AM
found something that resembles my problem
YouTube - clicking noise
Old 12-16-2010, 06:52 AM
Ruby911
ruby911's Avatar
Had a similar problem about a month ago, rebuilding the axles cured the problem.
- Farrell
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 12-16-2010, 06:55 AM
porsher
aston@ultrasw.c's Avatar
could be the diff, did you check the oil in the g box?
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 12-16-2010, 07:30 AM
Less brakes, more gas!
euro911sc's Avatar
All my clucks have been loose rear sway mounts...
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 12-16-2010, 08:10 AM
yup , and it was changed about 20.000 miles ago , no oil leaks whatsoever , not even from the cv boot .
-Michael
didn't even thought of that ... could you elaborate a bit
Old 12-16-2010, 08:13 AM
Flat Six
Flat Six's Avatar
Regardless of what the cause of your "clunk" is, 20K miles is a long time, IMHO, for a trans fluid change . . .
Check sway bar end links and sway bar mounts for play . . .
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 12-16-2010, 08:20 AM
Couldn't hurt to check that all the CV mounting bolts are torqued home and not backed out. I had my front engine mount bolts back out once. One was missing and the other was on its way. Made noise on torque reversal.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 12-16-2010, 09:19 AM
that's a new one ... I definitely haven't thought of that !
Old 12-16-2010, 11:07 AM
