dickster's Avatar
identifying boge dble tube gas shocks??
mr anderson states in his book that these boge gas shocks were std on 86 and 87 cars (i've not heard this mentioned on the board) - how do i identify them?
will i have problems changing to bilstein?? (just inserts) the book mentioned an adapter for konis - does this come with the shocks?
anyone done the swap?
richard
Old 01-27-2002, 02:02 AM
cary's Avatar
Generally its the color of the strut. But not always, paints cheap.
Black, BOGE. Green, Bilstein. Red, Koni.
The swap in my 77 was a breeze. With the car in the air. Maybe 20-30 per side.
But allow time to enjoy and observe.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 01-27-2002, 05:39 AM
Early_S_Man's Avatar
Black or gray usually means Boge ... but if you clean the lower 6"-8" of the strut or shock, you will fihd the mfr name stamped into the body!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-27-2002, 06:48 AM
dickster's Avatar
yeah mine are black and they're boge cause it says so!! but are they double tube gas shocks and if so is this a problem when changing to bilstein etc.??
richard
Old 01-27-2002, 08:16 AM
89Targa's Avatar
I assume you are talking about the frint shocks since you used the word "insert". The switch from boge to bilstein is easy. When you order the part specify that you want a bilstein insert for a boge strut. They drop right in. The double tube chatter doesn't make sense to me. Every shock has an inner and outer tube, maybe that is what they mean by double tube.
The switch from boge to bilstein in the back is even easier, assuming you can reach the top bolt on the passenger side.
Good luck.
Tom
'97 Turbo
'89 Targa
'04 Audi S4 Cab
'03 BMW 1150RT
Old 01-27-2002, 11:32 AM
dickster's Avatar
thanks i guess its not a problem then.
its just when mr anderson stated that a special adapter is required for konis.............
richard
Old 01-28-2002, 12:01 AM
