-   -   Outer boot (for shifter in tunnel) (http://forums.pelicanparts.com/porsche-911-technical-forum/580779-outer-boot-shifter-tunnel.html)
steely 12-16-2010 08:39 PM
Highly technical question here....
It looks like I am missing an outer and inner boot at the rear of the tunnel.
Stupid question are these boots worth replacing?
Will I have to remove the shift linkage from behind the tunnel ? (pls say no)
Looks like the PO removed it fer some reason:rolleyes:
I am hoping to effectively stop the cold air that is wooshing in the cab from the E-brake boot. Targa actually likes the cold, but I'd rather not have it blowing on my shifting hand.
Thanks!
no boot
http://forums.pelicanparts.com/uploa...1292560728.jpg
steely 12-16-2010 08:53 PM
Oops - I posted the incorrect part. I need the "sealing sleeve", and there is no inner boot. Item 20 on the right.
http://forums.pelicanparts.com/uploa...1292561602.jpg
RWebb 12-16-2010 09:13 PM
yes, I think they are worth it if you drive on the street.
of course, there are people who don't even seal the top strut mounts b/c it doesn't look as pretty, so maybe I (and the engineers at Porsche who designed the cars) are off base
lin7310948 12-17-2010 03:53 AM
i use a soft closed cell foam ..just cut a proper sized piece and wrap around the shifter rod and stuff to in the opening. works fine for me. dont usually drive the car in wet weather but it keeps it dry if i do and no cold air! too bad CV joints arrent that easy to enclose!
Targa Time 12-17-2010 05:25 AM
Dont you get a lot of road dust on the shift linkage and in the tunnel without it? It looks like it would be a easy repair.
KTL 12-17-2010 07:04 AM
The shift linkage beyond the tunnel is a piece of cake to remove. There's a shoulder bolt in the alloy coupler that you remove and voila', you can install your missing boot. No readjustment of the shifter is necessary, as the bolt can only fall into one position because there's a machined hole in the trans. shift shaft that the bolt threads into.
I'd put that boot on there. Keeps crud out of the tunnel. My racecar was missing the boot for my 915 trans and there was all kinds of debris in the tunnel (as well as some gear oil on account of a leaky shift shaft seal). Your G50 is slightly different and gear oil spillage is less likely due to the shaft seal and coupler design. But the debris issue still applies.
Also note that you have a big o-ring flopping around on your shift shaft. It's a makeshift repair prompted by a Porsche parts reference manual tech tip from the 74-89 book, which is probably a shortened version of a formally issued factory tech bulletin:
On 1987-88 model 911's which have a rattle noise coming from teh shift rod, the installation of a rubber o-ring on the shift rod may help eliminate the noise. Install as follows:
1. Remove shift rod access plate
2. With shift lever in neutral, disconnect from shift rod from coupling.
3. Move shift lever in 3rd gear position and slide rubber o-ring (p/n 999 701 969 40) over front shift rod
4. Reconnect shift coupling
5. With shift lever in neutral, slightly tension the rubber ring with a nylon tie strap to the left side hand brake cable guide tube. The distance from the shift rod flange to the o-ring should be approx. 100mm.
6. Reinstall access plate. Road test car. If rattle noise is still audible, increase tension on the rubber o-ring slightly
Pretty cheesy, eh? No need to buy the Porsche o-ring if anybody wants to do this quick fix. Any large o-ring from the hardware store will do.
CCM911 12-17-2010 07:41 AM
Dan:
I live pretty close to you(relatively). If you would like, we can install your boot in my heated garage. I have dropped my engine a lot, so I know exactly what Kevin is describing above. It will take about a half hour to forty-five minutes to install.
steely 12-17-2010 02:19 PM
Thanks for the replies guys.
lin7310948 I'd considered the foam idea, but now think I'll opt for the part since it sounds like it is worth it.
Yeah, she & I are just street (RWebb).
Targa Time - I wondered the same thing - didn't seem too bad in there, but I really didn't notice the air flow (and linked the dirt suction factor) until I started driving her this winter.
Kevin - the pic (with O ring is from 2 yrs ago when I was doing the front shift bushings and decided to inspect under the rear door. The ring had me stymied as to it's purpose - cheesy is right (chuckle). I really don't recall offhand if I removed it or not at the time.
Chris - thanks very much for your gracious offer. I'm in Maple Glen (Horsham twp) and work at LM in VF/KoP. (closer to you). Mind if I ping/PM you after the holidays/place the order?
Thanks all
m110 12-17-2010 02:27 PM
Mine was missing too (many mechanics toss it I've heard). Easy to replace, I didn't notice any noise difference but seems like a good I idea to seal out the elements. 1 bolt, $35 or so.
kodioneill 12-21-2010 10:17 AM
AH Ha That's how the air is getting into the front compartment and through the dash? I've tried to adjust hood. I thought it was a leak through the A/C condenser fan. Now I know. Sorry for the thread hijack.
RWebb 12-21-2010 01:22 PM
check the front lip seals also
DW SD 12-21-2010 01:54 PM
Ouch. That stings! Still hanging onto this from the other thread? SmileWavy
Porsche made their cars, like most car companies for a global climates. Some know the climate to which they'll expose their cars and plan accordingly.
I'd run the shifter boots just to keep dust out of the tunnel.
Doug
dshepp806 12-21-2010 02:01 PM
Doug
+1.
Doyle
88911coupe 05-25-2024 03:34 PM
Does anyone know exactly how far in/out the rubber sleeve/boot needs to be? I'm thinking it should just be inside the opening to the engine bay. Is it supposed to be pulled over the area in the engine bay that has the bolt?
rosewoodhill 11-02-2025 06:31 PM
I came by this thread searching to see how putting on the shift coupler boot is done. I tried for quite a while with the transmission mount installed with no luck. So, with the transmission supported, I removed the mount to get much better access. I managed to get the rear of the boot over the lip on the transmission. There's no real way to get it on the lip with the transmission mount on that I can see.
I'm adding two photos showing how the boot should look after installation for anyone else searching the interwebs for how to do it.
http://forums.pelicanparts.com/uploa...1762136984.jpg
