Caveman Hammer Mechanic
Fuel Injection Lines?
Hello,
I was wondering if the hard injection lines from a 3.0 would work on a 2.7? Thinking that elimination of the flexible plastic lines could be a better solution. Ideas? eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Band.
I'm guessing, but I'm guessing YES.
To be honest, the flexible lines make pulling injectors/testing flow a lot easier, but it's not like a person does that all the time. I saw a pic somewhere on here recently where a fella had stainless Flex lines from a Jetta. It looked pretty neat!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Fleabit peanut monkey
The hard lines can be bent/adjusted without problems for alignment.
The injector sleeves, outside o-rings, injectors and injector o-rings are the same for 74-83. Only thing I am ignorant of is the fitting at the Fuel Distributor. As Gogar says I am guessing yes as to fit. But one hard line and try it out. |
Fuel lines.......
They will work provided you have the fittings (reducers) for the FD. The fittings of the flexible fuel lines to the FD are the banjo type. While the metal lines are the flare type with adaptor/s (reducers). HTH. Tony |
That was userid stormcrow.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Possible thread hi-jack:
My old '76 Audi had braided stainless steel lines for all the CIS fuel lines in the engine compartment. Are there any equivalents for mid-70's Porsche CIS (short of having some made)? |
As noted the steel lines require the fittings on the FD to work on earlier cars. If you are looking for a source for braided steel flexible lines these guys make them:
J2 Precision Hose*::*'CIS" Fuel Lines I was quoted 240 for a complete set for my 76. I just opted to buy the correct polymide tubing and replace the lines myself. I figure the original lines lasted many years, replacement tubing should last many more.
76 911S Targa An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage! Last edited by Ray_G; 12-20-2010 at 04:32 AM.. |
