911 sc rear wiper motor wiring
Hi All,
Can anybody find a wiring diagram for the rear wiper motor on a '78 SC? I have searched but not had any success. If not does anyone know what each of the four terminals are? I guess there is a GND and 12V but I'm unsure why there's two others. The switch on dash has four connections which I guess go direct to rear motor but mine has failed and maybe motor has too. Any help appreciated, thanks Jon |
Caveman Hammer Mechanic
John,
I was looking at the wiring for my '75 in the FSM. Looks like the wiring is the same through '89. There are 4wires for mine also, a diode with different power and ground sources. I opened my wiper motor to see why it would only run for a minute or so. After removing the cover, it became very clear as to why it would only run for a short while. The spring to tension the motor brushes was a rubber band, that had aged and lost it's ability to tension the brushes. I replaced it with an o-ring and the motor works just fine now. Good luck Eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
hi Eric
Thanks for responding. Any chance you could post a pic of wiring diagram, i dont have this in my haynes manual or found online at all. thanks Jon |
Here ya go:
![]() If you want it emailed PM me your email eric
Any chance you could post some pics of your wiper motor in its mounting position. specifically the part where it mounts to the hinge and location on the deck lid outside?
Thanks eric
Hi Eric
These are the pictures: ![]() ![]() ![]() I'll try to PM you my email. |
Removed mine.....(1989)!
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
