leverpuller's Avatar
high rpm glitch
between 5 and 6 thousand rpms i'm getting a hesitation to which I can't tell whether it is ignition or fuel. Once I stop then test again all seems normal from start to 5 grand then the miss occurs..I can run all day up and down the rev scale as long as I don;t hit 5 to 6 k rpms. Any idea where I should start?
Old 02-16-2011, 11:11 PM
muck-raker
kidrock's Avatar
well, a good start would be to tell us what year car you have. With so many different models having points, MFI, CIS, etc.
My personal opinion is to check your dizzy cap, rotor, plugs and plug wires. Those are the usual culprits for missing at RPM.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-17-2011, 01:31 AM
I had this on my 3.2, turned out to be a bad cylinder head temp. sensor, replace it and ran perfectly
Old 02-17-2011, 06:56 AM
