			The guy that worked on my ventilation system screwed it up. Only the driver side heat-defrost works and the ac/ defrost only works on the passenger side.I think the tubing in the trunk under the windshield is done wrong. My blower in the engine compartment does not come on . There is no power coming in from the lead wire.
				Anyone have any good diagrams? Thanks 1983 911 SC  |
			Are any fuses at play here? Particularly on the engine blower?
			Doyle
	Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia  |
			 83 911 Production Cab #10
			Black relay & fuse in the Engine Electrical Panel and the Red Lever (between seat) micro switch.
	Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger  |
