Colby's Avatar
Send a message via AIM to Colby Send a message via Yahoo to Colby
Adjusting clutch pedal on Carrera
I just installed a new clutch in my '84 Cab. The problem is that the pedal goes to far to the floor (I can even sometimes hear metal rubbing in the clutch...release bearing and fork I presume...when I fully depress the pedal). Is there a way to limit how far down the pedal goes, like some sort of stopper? I looked on the wood board and saw nothing; the pedal goes until it hits a metal stopper welded to the metal floor.
Colby
Old 01-28-2002, 06:40 PM
Send a message via ICQ to old_skul
There should be a rubber slider at the end of the slot where the clutch arm travels...if not, you are missing a part.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 01-28-2002, 07:53 PM
Colby's Avatar
Yeah, I found a photo of this in a book and I have the slider but it is missing the rubber piece. Anyway to get just that piece, or make something comparable (drill in a piece of wood)?
Colby
Old 01-28-2002, 08:08 PM
Clark Griswald's Avatar
The wood board behind the pedal should have an adjustable stop. Perhaps your is missing. If so, you at least see a threaded hole for the screw the holds the stop.
Clark Retired, I'm now posting under my real name
Chuck Moreland
Day Job - Elephant Racing
Basic Transportation - '86 Cab - "Sparky", '77 Targa - "The Peaper"
Old 01-28-2002, 10:44 PM
