Pelican Parts Gaz analyser, what brand
Hello,
Do you have good plan for buy gaz analyser for CO/CO2 ?
What is a cheap good brand ?
Have a nice day
Nicolas
1992 C2 964 (Nevada USA & France)
Old 09-24-2014, 12:46 AM
cycling has-been
bkreigsr's Avatar
have you tried google or bing?
within the MFI crowd that does their own tuning, its usually Gunson
Amazon.com: Exhaust Gas Analyzer
Old 09-24-2014, 08:15 AM
theiceman's Avatar
innovate LM-1 is a good meter but is certainly not cheap.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-24-2014, 08:45 AM
Gunson is mainly designed to measure idle CO. It's only effective on the road at steady state RPM/throttle position. It's not as responsive as a proper wide band O2 system.
Sherwood
Old 09-25-2014, 08:43 AM
Josh D's Avatar
Sherwood
This is a conflicting statement to me. Idle and steady state driving down the road are two different conditions.
Are you saying that it is designed for measuring CO at idle, but doesn't work well in this capacity, but works well at a steady cruise?
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 09-25-2014, 10:37 AM
I could see how my response could be confusing. The Gunson is most accurate and useful under steady state engine operation. This includes both idle and constant throttle/RPM. Variations in throttle opening take awhile to register on the display.
In addition, for road use, suggest fabricating a clamp to hold the sensor assembly in the tailpipe. The supplied spring-tension retention system will not prevent the exhaust from spitting this out. added:... nor prevent the exhaust from melting the PVC collection hose feeding the gas analyzer.
Sherwood
Old 09-25-2014, 10:49 AM
U should install a wideband o2 controller. Itll open up tuning capabilities that you dont have with the stock o2 sensor.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-25-2014, 11:52 AM
Josh D's Avatar
Sherwood
Ok, that makes sense. Good for base idle CO setting on a CIS car, but not so good for measuring CO in dynamic conditions.
Thanks for clarifying.
Old 09-25-2014, 12:45 PM
