-   -   knod socket problem (dashboard) (http://forums.pelicanparts.com/porsche-911-technical-forum/582678-knod-socket-problem-dashboard.html)
dany911 12-29-2010 05:11 PM
This is my problem,
I have the 2 knobs in the dash ( defrost & fog lights) and every time I want to use it , the knob stay in my hand ( when pulled) I have remove everything to see if some parts could be damaged but , nothing. It looks like the end of the knob is to short and cannot reach the socket.
What do you think and do I have to change the socket??
Help me please:confused::confused:
http://img836.imageshack.us/img836/1447/133je.jpg
dany911 12-30-2010 07:37 AM
Nobody as an idea where I can find this part?
I went thru all pelican parts and cannot find it...
http://img401.imageshack.us/img401/5378/90306a31.jpg
Roby466 12-30-2010 07:46 AM
pelican sells them. I had the same problem and they only list the defrost switch which is the same as the 2 stage fog switch on euro cars. The new switch comes without the knob so yours will be used.
911-613-147-00-OEM
I see that you're in Montreal, try giving a call to nineapart for used switches, they are sometimes just as expensive as new parts though...
Or check with the dealer.
later
group911@aol.co 12-30-2010 07:48 AM
So when you screw the plastic collar down all the way onto the part int he dash- the actual switch-, you still can't screw the knob in far enough to get it to hold?
dany911 12-30-2010 07:57 AM
Thanks guy's
Yes , this is my problem Group911. No grip at all and the knob look's intact
I have to change both ( defrost and fog lights) . Thanks Roby 466 for the part number. I will compare with nineaparts too.
mfiazzo 12-30-2010 08:24 AM
I bought used switched from these guys. They were reasonably priced and worked great.
Weekend Rides LLC - One of the largest used Porsche 911 parts and rebuildable Porsche salvage companies in the world.
Joe Bob 12-30-2010 08:46 AM
Sounds like the internal threads are stripped.
