-   -   What engine oil do you use and why, not asking which is better, just curious (http://forums.pelicanparts.com/porsche-911-technical-forum/583272-what-engine-oil-do-you-use-why-not-asking-better-just-curious.html)
jleonej 01-02-2011 03:18 PM
Curious as to which engine oil everyone uses and why?
equality72521 01-02-2011 03:20 PM
Oh god....
RSTarga 01-02-2011 03:20 PM
Mobil 1 15-50, It's worked for me for 35 years.
gruppe75 01-02-2011 03:24 PM
Ditto, Mobil 1 15-50 is available locally
RWebb 01-02-2011 03:31 PM
Libom 2
Hodgey 01-02-2011 03:33 PM
Brad & Penn
NewfieMZ3 01-02-2011 04:06 PM
Not another oil thread? Do search on oil and be prepared for an onslaught of info......hope your not busy for the next week.
Flieger 01-02-2011 04:08 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html
http://forums.pelicanparts.com/porsche-911-technical-forum/535002-brad-penn-20w-50-good-choice-sc.html
http://forums.pelicanparts.com/porsche-911-technical-forum/579968-my-oil-looks-reddish-all-sudden.html
http://forums.pelicanparts.com/porsche-911-technical-forum/574845-what-do-you-think-oil.html
dicklague 01-02-2011 04:58 PM
what year and model is your 911?
I use petroleum in my 1973
tomphot 01-02-2011 05:24 PM
OK - Brad Penn
80-911SC 01-02-2011 06:05 PM
new year ..... new oil thread ??????
barndoor 01-02-2011 06:58 PM
No !
Oh the humanity.....
BRAD PENN.
GaryR 01-02-2011 07:28 PM
Finally found the ultimate -
http://www.3inone.com/files/images/3oz-8oz-92314687.jpg
barndoor 01-02-2011 07:31 PM
3 in 1
just the smell of 3 in 1 brings me back to my youth,working on old schwinns.....
barndoor 01-02-2011 07:32 PM
Veronika
Veronika only uses Brad Penn in her '76 911S......http://forums.pelicanparts.com/uploa...1294025538.jpg
village idiot 01-02-2011 07:58 PM
Currently, Valvoline VR1 20w50. But I think I'm going back to the Harley Davidson 20w50. Engine seemed to run cooler and less noisy with less smoke(valve guides need attention)
dmwallace 01-02-2011 08:14 PM
Swepco 306 Supreme 15w-40
If you want to learn more about oils for our cars you should check out the links that Flieger posted.
nineball 01-02-2011 08:43 PM
vr1 20w50. it's available locally, decently priced and specs out to the needs of my engine (zddp).
HarryD 01-02-2011 10:35 PM
I have it on a good authority (http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html) that we need not waste our good money on fancy oils....
:D ;)
http://www.buythecase.net/uploads/pr...2700069061.jpg
WolfeMacleod 01-03-2011 01:05 AM
Oil? What?
bsimonson 01-03-2011 01:30 AM
I use a locally available oil, Agrol Super Syntet 5W-40. It's a SHPD-oil with all the right additives. I believe that synthetics are superior in many ways and I want as good lubrication as possible when the engine is cold, hence a 5W oil.
stlrj 01-03-2011 02:45 AM
Any brand off the shelf 10w30.
Why? Best lubrication at cold start where most wear occurs and cooler operation due to less internal friction, eliminating the need for anything more than a stock fender mounted trombone oil cooler.
Cheers,
Joe
74 w/ 86 3.2
craigturbo02 01-03-2011 02:54 AM
Mobil 1 15/50 always used it.
jleonej 01-03-2011 04:53 AM
I know, I know not another oil thread but I was just curious as to who uses what brands. I am not looking at changing what I use or anything of that nature. I don't want to know who thinks what brand is best, I was just curious as to who uses what. I happen to use Mobil 1 in my 86.
esample 01-03-2011 08:59 AM
Why, Brad Penn of course.
-e.
cmcfaul 01-03-2011 09:51 AM
No Mobil V-twin 20-50 users out there. Thought this was a full syn designed for air cooled engines with lots of zinc. A bit pricey though
Chris
73 E
GaryR 01-03-2011 09:55 AM
All I use is V-Twin in my race car
WIL84911 01-03-2011 10:49 AM
Royal Purple 20 50 but it's no longer on sale so I may be switching.
aigel 01-03-2011 12:00 PM
On the SC I ran Castrol GTX 20W50
On the 993 I run Mobil1 15W50
George
aftermath 01-03-2011 12:00 PM
AMSOIL
AMSOIL - SAE 20W-50 Synthetic Premium Protection Motor Oil (ARO)
Hi zinc formula.
You can order from me :)
cattman 01-03-2011 12:24 PM
Mobile 1 15-50.
I use it on both my Supercharged 997S and my '97 911. I buy it in the 5 qt jugs at WalMart when it's on sale.
CATTMAN
p911dad 01-03-2011 01:29 PM
I also use the Mobil 1 V twin 20w50. I get it from AutoBarn.com.
86 911 Targa 01-03-2011 02:54 PM
Mobil 1
Mobil 1 decades!
dshepp806 01-03-2011 03:21 PM
I like simple questions///(right?)
BP 20 W50,..in the South,..all year,..every 3k miles...no cold starts below 25 degrees F.....(but that;'s just me).....
Definately: no additives,....(aside from healthy injections of Techron....)
Best,
Doyle
HarryD 01-03-2011 07:27 PM
errrr... what car?
HarryD 01-03-2011 07:29 PM
Cliff Notes for Oil Selection
Cliff notes version:
Older engines (pre-mid 90's) need high levels (around 1200 ppm plus correct level of detergents) of Zinc (Zn) and Phosphorus (P) to protect cams and other high pressure surfaces.
With the introduction of roller tappets in most engines by the mid-90's, this requirement is relaxed and Zn and P levels can be reduced. The EPA pressured API to reduce the Zn and P levels to (hopefully) extend the life of the catalytic converter which is poisoned by Zn and P. They complied.
Use 20W-50 or 15W-40 oil. Brands frequently sugggested here, in no particular order, include:
Brad Penn 20W-50
Valvoline VR-1 20W-50
Kendall GT 20W-50
SWEPCO 15W-40
Royal Purple
There are others as well.
Milo2361 01-03-2011 07:56 PM
I had emailed shell about their oil and Zn and P content, received an email next day from them saying it is rated at or above 1200ppm. Ive been using Shell Rotella T 15w-40 basically since i acquired the car(10w-40 when it gets damn cold in NE). no problems yet, oil change intervals of 3-4k miles. cost is around $2.50 a quart.
Neel 01-03-2011 09:11 PM
Since you asked, Royal Purple..
m110 01-03-2011 09:39 PM
Brad Penn 20W-50 because people I trust use it...the threads seem to indicate it works well and it is relatively cheap for me.
Swepco 306 15W-40 also seems to work accoording to the experts, a little more pricey for me. If changing oil hyperfrequently I don't think it really matters, as long as it is heavy.
