The RPM guage on my 84 Targa has a mind of its own. The engine runs great as always, but recently, the RPM guage fluctuates wildly and will drop to 0 or flip to 7k; sometimes it will reflect the normal range of rpm's during idle and shifting, although the baseline will be at idle 1200 when it normally would be around 800. Help! Any suggestions?![]()
With a CDI, Capacitive Discharge Ignition, a jerky/jumpy tach is generally an early indication that your battery is being over charged.
I'd check the area around your battery for acid damage too. This is pretty easy to check using a voltage meter -- it should be jumping around a fair bit if the regulator is going bad and steady at 14 volts or so if OK. I was clueless on all of this when it happened to me years ago and suffered a failed tach, needed to get my dme rebuilt and have some battery area corrosion fixed after letting my failed voltage regulator situation linger too long. |
HTH.
1984 Targa |
RETIRED
Get a multimeter and test the battery at the terminals.
12.5 at rest 12.5-13 at idle 13.5-14 at 2500 rpms...... Over 14 and you have a regulator issue, under 12.5 your alternator is going....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
| Tags |
| 1984 , rpm , targa 911 |
