grahamkissack's Avatar
Cheaper alternative to yellow fog light lenses?
I cant bring myself to spend $55 per lense for yellow fog lights on my 1980 SC. Would these bulbs be compatable in my stock fog lights?
Thanks...
"Penelope" 1980 SC Targa in Grand Prix White
Old 12-20-2010, 05:59 PM
MrScott's Avatar
Don't know about the bulbs but I remember a thread on yellow headlight lenses where someone mentioned a yellow tint spray applied to the inside of the lens...
Old 12-20-2010, 06:19 PM
RETIRED
Joe Bob's Avatar
Go to Michael's the hobby store. Krylon makes a window stained glass tint, it comes in a rattlecan. Paint the INSIDE......keep the nozzle clear. It likes to clog.
Van is like 7.99.
2012 ML350 3.0 Turbo Diesel
Old 12-20-2010, 06:24 PM
Thanks....can a painted surface really handle the heat and stress of the inside of a fog light?
Old 12-20-2010, 06:48 PM
Formerly known as Syzygy
Canada Kev's Avatar
Go with the Krylon if you want yellow lenses. Use yellow bulbs if you want to stick with clear lenses: CPI Gold Selective Yellow H3 55w Bulb.
BTW, 5000K lights are not yellow, but a bright bluish white, like HIDs.
Kevin
Old 12-20-2010, 06:50 PM
RETIRED
Joe Bob's Avatar
It stood up to a 80/100w H4 bulb.....
MrScott's Avatar
Yes, I noticed that too - the box says 5000K but the caption below says 2500K...
Maybe they are first tinted blue to increase light output then tinted yellow for effect
1980 911SC
Old 12-20-2010, 06:56 PM
Thanks for the graphic on colors...most of the yellow ones seem to be 2500K rating. For the price of $20 per pair, I'll give it a shot plus I can keep the lenses clear.
Old 12-20-2010, 07:01 PM
Happiest when Tinkering
gsmith660's Avatar
Thanks...
First off those are not HID if you look at them there is no xenon chamber there is a filament (at least it looks like a filament) big difference second 5000K is the temp the light emits for them to have 5000K and 2500K on the same box is misleading I would set the box down and back away. What I suspect is the filament emits 5000K and they put a tint on the bulb to make it emit 2500K whatever the price they are not something I would give another look at.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-20-2010, 07:07 PM
gsmith660's Avatar
I saw a close up on amazon and that is a filament which means it can't be a xenon HID bulb probably a halogen but for 5 bucks I would bet it isn't even halogen.
Old 12-20-2010, 07:13 PM
I'm not really interested in HID bulbs...just a cheaper alternative to $110 for yellow lenses since I live in foggy location. Here's another possibility that's listed as 2500K ...
Old 12-20-2010, 07:14 PM
gsmith660's Avatar
My point is they are mis-representing the product so the quality IMHO is suspect so would you want to take the time to pull your lens off your fog lights put these in there and just when you need them most they are burnt out. You might look at these PIAA is a good company and quality is know PIAA Plasma Ion Yellow (H3) Halogen Light Bulbs|PIAA Light Bulbs|PIAA High Output Automotive Light Bulb
Old 12-20-2010, 07:25 PM
Alii&Maui
Jesset100's Avatar
Daniel Stern Lighting Consultancy and Supply
Copyright ©2009 Daniel J. Stern
I did this with new clear lenses I bought from Pelican. Make sure you clean the inside glass good then what I did was put the two lenses next to each other and laid down three coats to the inside of the lenses. This is how it looks;
Easy project
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 12-20-2010, 07:38 PM
Reifle's Avatar
I believe with HID you need an extra transformer/power pack. So the bulbs that are shown are not even close to HID. Alot of stuff coming from the Asian countries are also not what they have on the labels. Try to stick with the proper products - OSRAM or Phillips and Bosch - make the right bulbs for just about any headlight or auxilary light. Around here the wiring has been suspect and melted thru some very expensive headlights! Be careful - as well alot of the over seas products are not DOT approved.
'77 Porsche 911S
Old 12-20-2010, 07:41 PM
Thanks...
Maybe they decided to add the two 2500 Kelvin bulbs to arrive at 5000K (BTW, not possible). However, might be good enough where they're manufactured. How much? Someone mentioned $5? A single H4 halogen bulb is about that much (street price). They must use the acronym, "HID" for some other meaning.
For fog lamps? Try them.
Sherwood
Old 12-20-2010, 08:10 PM
The ones I'm posting are about $15 for two...it may be worth getting better quality PIAA bulbs for $40 as was suggested...I'll check things out my local auto parts store.
Old 12-20-2010, 09:48 PM
haycait911's Avatar
FWIW the yellow paint is easy-peasy. and reversible with a bit of lacquer thinner.
SWB with yellow headlamps
Old 12-20-2010, 10:07 PM
Canada Kev's Avatar
Riiiiightt......
Yes, if you want yellow light from your fogs, the least expensive route will likely be to paint the lens with some proper transparent glass paint. If a bulb burns out, you can still replace it with a regular white one in the middle of the night from that little gas station just east of nowhere and still have yellow light.
If you want yellow bulbs, just go and get some Osram, Phillips or Narva. Maybe Bosch too, but I think they're just reboxed Osram... For the most part any others are just overpriced with questionable "features". Technology such as plasma ion or similar might not be all they're cracked up to be. Read the little bit in the Stern link above for some good information. Here it is again: Daniel Stern Lighting Consultancy and Supply
This whole project shouldn't cost you more than about 25 bucks, whether paint or bulbs. Good luck, and let us know what you did and how it turned out.
Kevin
Old 12-21-2010, 05:28 AM
wwest's Avatar
How about simply purchasing a set of AW, All-Weather, fog light bulbs....?
Old 12-21-2010, 07:37 AM
I used Superbright LED yellow H-3 LED replacements and are really happy with them.
Old 12-21-2010, 07:45 AM
