irl irl is offline
irl's Avatar
Send a message via AIM to irl
How do you run braided oil lines
How do you run braided oil lines when installing a front cooler, Where do they typically go, where are holes cut for them, any photos??? Thanks
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 01-03-2011, 11:13 AM
Ed,
Is this a race or street car? Inner front fender mount or up in the valance?
You don't need to add any additional holes for a front cooler (street car), depending how you do it.
For race cars, I like putting the lines inside the car on the passenger side floor so that involves some strategically placed holes.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-03-2011, 11:42 AM
irl irl is offline
irl's Avatar
It will be a simplified hard core street car if that makes sense. 74 RSR backdate, rollcage etc but will still have a carpet kit. Id like to go outside but the lines are so fat I cant imagine they run where the stock lines usually run????
79 SC unmolested
25 GTS
Old 01-03-2011, 11:52 AM
grateful user
don gilbert's Avatar
i have been saving this pic for when i get to mine someday
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 01-03-2011, 12:25 PM
MBruns for President
JeremyD's Avatar
Lots of pictures posted here - Use the stock Porsche thermostat - it has a relief plunger that you need. Search for front oil cooler install.
Me personally - I didn't like the idea of introducing 200 degree hot oil to the inside of the passenger compartment even with braided SS lines - so ended up springing for a set of elephant racing lines.
Old 01-03-2011, 12:38 PM
irl irl is offline
irl's Avatar
Don great photo, where does the line go from here? Are the only two options inside the car or outside underneath. Thanks all and Ill also do a search.
79 SC unmolested
25 GTS
Old 01-03-2011, 01:04 PM
Jeremy is right on,...don't use those bloody Mocal thermostats: those are really best suited for wet-sump systems.
Use the factory thermostat which incorporates the very important pressure relief valve. That both protects the front cooler as well as shunts uncooled oil back to the engine when necessary to prevent oil starvation at high RPM.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-03-2011, 01:06 PM
I suggest looking at the many threads on front or fender-mount oil coolers and lines. In either case, the rigid factory lines (or equiv.) end about a foot away from the passenger side headlight bucket. From there, either factory lines to a factory cooler or metric-to-AN hose adapters and AN hose to the cooler(s).
Sherwood
Old 01-03-2011, 09:03 PM
proffighter's Avatar
Here you'll find my setup:
External Oil Cooler Install
BTW: I disassembled both of the thermostats and can't see any difference technically. Both have a little bypass when closed
Roland
930 Turbo '81 Too many modifications to list
Old 01-03-2011, 11:44 PM
