| Registered Join Date: Jun 2000 Location: Los Osos, CA
				 |  Clutch position sensor? 83SC
			This weekend when I adjusted my clutch, I had to tighten the cable at the clevis (at the pedal end of the cable) to allow for the correct adjustment at the transmission.  I noticed a small lever close to the clevis that I think is activated when clutch pedal is all the way up.  Any ideas what its function was (it took some damage in the process). ------------------ Graham Archer 83 911SC Cab | ||
|  07-09-2001, 06:48 AM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			it's to shut off the cruise when the pedal is depressed.
|  07-09-2001, 07:09 AM |
