SSI heat exchangers
I was wondering why my SSI is discolored is there a way to restore them. I plan on putting a new exhaust unit in from M&K Active muffler, so I want to make sure it's all looking good. Also I did see some stampings on the SSI what does this identify?
Serial numbers.
No need to clean them up unless it bothers you. They all tend to patina over time….the road, the heat, possibly some oil, etc.
Ass-engine Nazi slot car -- PJ O'Rourke |
The stamping is just the part number.
I have never seen SSI's discolored like that. Baked on oil and salt corrosion? You might try some red Scotch Brite to shine them up. |
OSPHO 0000 steel wool.
What if you have them soda blasted?
'71 914-6 #0372 '17 Macan GTS |
Enginerd
There is a new process that I'm seeing posted on IG from various dry ice cleaning folks. I don't know anything about it, but it's supposed to take the SS back to near original condition. Seems like black magic right now, only because I haven't looked into it at all yet. You might want to look into it though.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
1978 911 SC
Just had mine vapour blasted. They came out looking new.
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler. |
if they are stainless, some rubbing compound, scotch brite pads, rags, and elbow grease. Dremel with 1" abrasive wheels for the nooks and crannies.
Finish with metal polish if you really want to make them shine. Here's mine:
A professional ceramic coat would offer a more permanent solution.
Wouldn't work for me though, steep driveways, speed bumps with a low ride height. |
Wow @thetorch those look fantastic.
Dry ice could be an option if I do my undercarriage. Thinking if I might go with OSPHO product to clean them looks promising well reviewed. I really don't want to remove them so I hope I can make them look good without removal i read somewhere that you have to be very careful in removal as the studs can break and require heat sometimes. |
Are there air-injectors (unconnected and possibly left ' open') still in the block? (as seen on the last 2 images)
79 911SC sunroof Coupe (ROW) Last edited by TJJSC; 02-06-2023 at 01:21 PM.. |
Sorry I am new owner should the air injectors be connected to something and what is the purpose of them I've noticed one of them has a bit of oil on it I will add some pictures
Bar Keepers Friend is excellent on stainless steel
Those air injectors used to connect to a distribution tube that was fed by the air pump. You should be able to remove those injectors and replace with metric plugs.
PCA Member since 1988
TJJST: Those fittings are just blowing exhaust out under the engine, and probably making a racket too. Remove and plug the heads ASAP.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Here is what those injectors look like. I expected they would be hard to remove, but mine screwed out easily. Your job is complicated by the heat exchangers in the way, but you can probably get a socket with an extension on them.
![]() Pelican sells a plug for the ports, Part PEL-BRC-02. Mark
1979 911SC Targa |
79 911SC sunroof Coupe (ROW) |
Cleaning used SSI exhausts
It can be done, just takes lots of work! Here is a set that I cleaned up after having been on my SC for about 10 years. I don't remember exactly what I used as a cleaner but probably tried several things.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Nice they look great after 10 years worried about removing the air injectors I feel like they have been on for quite some time. Hopefully some penetrating oil will do the job. I think for me it's best I remove the SSI to get a good clean
