Oil filter thread size
Hi guys,
I searched but wasn't too successful. Does anyone know what the thread for our oil filters is? Thanks, Amir |
what year?
sorry, that's pretty important but its a 76
According to WIX site:
zoom Part Number: 51283 UPC Number: 765809512832 Principal Application: Porsche (71-93) All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 5.879 Outer Diameter Top: 3.663 Outer Diameter Bottom: Closed Thread Size: 1-12 By-Pass Valve Setting-PSI: 28-30 Anti-Drain Back Valve: Yes Burst Pressure-PSI: 365 Max Flow Rate: 12-16 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.834 2.462 0.255 Close Window |
| All times are GMT -8. The time now is 07:50 PM. |
