ornas's Avatar
Location: Vilnius Lithuania (it's in Europe and it's not Russia)
none cylinder/head gasket
Hi, I have disassembled my 86 3,3 turbo engine and there were no cylinder/head gasket. Is it possible that engine was assembled without them, couse none of head stunds were broken and could not miss 6 gaskets.
Old 03-14-2011, 01:38 PM
I would rather be driving
jpnovak's Avatar
There is no gasket on your 3.3 turbo motor. The 97mm cylinders have a machined mating surface with a slight bevel. This mates to the machined mating surface on the cylinder heads.
You have no problems. It is correct.
Make sure the head and cylinder are in spec (or machined to spec) before remounting.
Old 03-14-2011, 01:49 PM
