Koozy
914magazine's Avatar
Pressure plate ID question
I need to ID this pressure plate I have. Can't seem to find another one with these numbers. It has an aluminum disc with the steel plate sandwiched on it for the face.
Numbers on the inside are: 102 101 F&S 9 74
On the outside it says: typ m 215 SCHWEINFURT
I know it was used with a 901 trans and a type 4 engine but should work the same for a 914/6 conversion.
Anyone know what this is? I was thinking it was a early S but now think it's just a "sport". Is the "sport" aluminum?
Looks like this:
Mike Koozmin
1970 911 3.8 CF RSR - Polo Red
1974 914 GT - angry twin-plug 2.7 AX beast
Old 01-14-2011, 09:37 PM
Sounds like a '69S pressure plate - can you post a picture of the other side ?
Incidentally, if it is the '69S version it will only work with the corresponding (thinner) driven plate (clutch disc) which is NLA ...
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 01-15-2011, 02:32 AM
Yes , If it is steel faced it is the one.
Old 01-15-2011, 10:08 AM
Koozy
OK, got it. Thanks. Just making sure it wasn't a different PP that was made after the "S" to eliminate the need for a thinner disc. it indeed has a steel face.
Mike Koozmin
Old 01-15-2011, 10:15 AM
