JTO JTO is offline
Fuel Level Sender
Hi Folks,
I have a mysterious problem with my car's fuel level sender. The gauge reads normally on the upper half of the range but doesn't drop below the half full mark. The strange thing is that the fuel light works normally, e.g. the low fuel light comes on when there's two gallons in the tank. The gauge still reads half. What's up?
By the way I pulled the sender out, cleaned it, cleaned the contacts.
Thanks,
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 07-20-2004, 08:13 AM
911SCfanatic's Avatar
Got the same problem, however, my problem started after I replaced the fuel level sender gasket.
Bill G.
'68 911 Ossi Blue coupe
Old 07-20-2004, 08:28 AM
jdowty3's Avatar
I have a similar problem and replacing the sender did not fix it. I think mine is a ground problem in the sender connector or a problem with the guage.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 07-20-2004, 08:45 AM
Sounds like exactly what my SC was doing when I got it, I pulled the sender and everything looked OK there. I pulled the guage and found that it was sticky; cleaned it and never have had the problem since then.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 07-20-2004, 09:09 AM
JTO JTO is offline
So Charlie,
You suggest that the needle on the gauge may actually be hanging up? I'll also look at the electrical connections.
Thanks,
troy
Troy
Old 07-20-2004, 09:57 AM
For some reason I started out blaming the sender, but the ultimate fix was popping out the left gauge assembly and doing a simple cleanup inside the fuel side.
This was 20 years ago, but ISTR the gauge was jamming in the lower half of its motion and the empty warning light was working because it triggered from a separate contact at the bottom of the sender ??
as always, YMMV
Charlie Baer
Old 07-20-2004, 12:57 PM
i have the same problem on a 72 T. when i cut the power, the needle falls to zero.
thabaer, do you recall this being the case with yours?
any other have any luck cleaning theirs out?
thanks
matt
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 09-27-2004, 06:33 PM
Mine did this, I believed the gauge and not the light and ran out of petrol. I replaced the sender and all is OK.
Regards
Bruce
Past 89 3.2 Carrera (Sold), 94 3.6 Turbo (Sold)
Present 94 C36 AMG M-Benz, 93 SL500 M-Benz, 08 C63 AMG M-Benz
Old 09-27-2004, 08:03 PM
JTO JTO is offline
Mine indeed turned out to be a needle hanging up in the gauge. Once freed, it work normally.
Thanks,
Troy
Troy
Old 09-27-2004, 09:26 PM
I had the same problem , and last weekend, while cleaning my gas tank, I pulled the sending unit apart. Take the sleeve off the tank sending unit by removing the small nut on the bottom, and slide the the unit out. Very easy to do. I bet you will find the lower half is rusty and does not let the float drop down. A little bit of emery cloth or find sandpaper will solve the problem. DO NOT sand or break the guide wires. The float should slid up an down the rod.
Terry
Putting it back together takes all the time because you are trying to put that small rod thru the hole in the bottom without breaking the wires.
Terry Hastings
Baltimore, MD
1972 911T
LTHSURVEY@AOL.com
Old 09-28-2004, 06:00 AM
Designer King
Paulporsche's Avatar
If you tap on the gauge while it is reading higher than it should, and then the needle falls, then your gauge is sticking. Clean it as the others have said.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-28-2004, 06:19 AM
jdowty3's Avatar
From those who have cleaned their fuel guage, what process did you use? I removed mine from the guage holder but was afraid to try and pry the needle off which seemed to be required to get any farther in to the guage unit. Has anyone sprayed one out with electrical contact cleaner\lube?
Jim Dowty
Gruppe B #309
Old 09-28-2004, 08:08 AM
Regenerated User
72doug2,2S's Avatar
Bump
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 09-28-2004, 01:21 PM
KCPSG's Avatar
I just recently had taken my gauge apart and found that a pair of needle nose pliers did the trick for removing the needle.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 09-28-2004, 01:30 PM
Because of the thin wires in the fuel sender, I cleaned mine by putting it in a jar of warm diluted Marine Clean (from POR-15). This removed all the gum/residue. Originally the float in my sender kept getting stuck when I inverted it. It was very smooth after the POR-15 treatment.
1969 911T (Olive. '70 E engine and '72 915 gearbox)
Old 09-28-2004, 02:11 PM
Regenerated User
72doug2,2S's Avatar
Not to hijack this thread, but has anyone here had clearance issues with the replacement tanks and senders. I had to hacksaw my replacement sender to get the sender to fit into the repro tank.
I couldn't tell whether the new sender would have worked with my old tank as I had dented the bottom from a road hazard.
'72 911T 2,2S motor
'76 BMW 2002
Old 09-28-2004, 02:42 PM
fwiw.. there is a rubber gasket available.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2004, 02:50 PM
I am my 911's PO
'78 SC's Avatar
re: cleaning sender slider wires
I had very good results cleaing the wires and contacts using a swab wetted with lacquer thinner. The gummy deposits came off easily. Use a light touch to avoid stretching the slider wires.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 09-28-2004, 03:20 PM
Regenerated User
72doug2,2S's Avatar
To clarify, the sender tube was hitting the bottom of the tank. It wouldn't sit down.
'72 911T 2,2S motor
'76 BMW 2002
Old 09-29-2004, 06:58 AM
JTO
prior to fixing your gauge, when you turned off the key, did the needle fall to zero?
Matt
Old 10-03-2004, 09:19 PM
