SLR SLR is offline
SLR
Door handel
I Brooke the trigger on the driver side. So now I have second hand
one but the lock part is not the same. my old lock fits in ok but and works
but when I fited it it would not work on locking. So what I m going to
do is use the old handel and use the new triger, but I can't get the bolt thing
out of the new handel. I have tryed vice grips but it will not undo.
any help would be handy.
Thanks Steve.
Old 01-13-2011, 10:26 PM
1980SCMan
Alan Lindquist's Avatar
These plastic handles break. You can buy the right handle to replace it from our host for about $25. Mine broke. I solved the problem with a pull strap. I'll soon replace the stock panels with RS panels which have a proper strap to pull. If you want stock, buy the correct part.
Old 01-13-2011, 10:32 PM
SLR SLR is offline
SLR
Sorry it is the outside handle.
Old 01-13-2011, 11:17 PM
dshepp806's Avatar
Have you pics?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-14-2011, 01:43 AM
JerP's Avatar
I replaced the same door handle trigger and don't remember any difficulty just popping the trigger out.
A picture would help.
Jeremy
85 Targa
Old 01-14-2011, 04:41 AM
BlueWing's Avatar
Not sure if this PP link will work but it sure helped me recently when I fixed mine or just search door trigger and you will find lots of help
Door Handle Assembly
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 01-14-2011, 05:23 AM
more entertainment
911 door handle triggers
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-14-2011, 05:49 AM
just use the trigger from the replacement handle in your old handle.
206 637 4071
Old 01-14-2011, 08:27 AM
