Charles Freeborn's Avatar
Winter projects
... for the old girl ('74)
Change Tunnel fuel line (NOT looking forward to this one!) '74 was a bad year for this...
Pull pedal cluster and change throttle linkage bushings, as well as remaining ball cup joints.
Install Sein Gate while the tunnel is open.
Pull alternator and hopefully I've got the "if you're lucky replaceable brushes model". Otherwise shove some lube wherever I can, bearings if possible and clean it all up.
Pull CIS, check, re-seal, change lines, etc, then check pressures and set mixture (too lean now)
Test, and possibly change Oil temp and pressure senders. Investigate installing a head temp gauge.
Improve ducting from front valence to oil cooler - add fan.
Send remaining gauges for refreshing to Seattle Speedometer.
Install MSD ignition system
Find whatever in tarnation is clunking around on hard cornering. I'm thinking someone (maybe me) dropped a socket in the tunnel, or inside a rocker or somewhere.... it's driving me nuts!
Re-skin Targa Top
Look into a better seat with 6 pt harness for track days.
Make and install door panels, pockets, etc.
Re- work heater - defrost - fresh air system. Going full manual - no fan.
Delete ashtray, make svelte knee guard - clean up dash.
That should keep me busy for a few days... What's on your list?
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 10-23-2014, 09:46 AM
83 911 Production Cab #10
JJ 911SC's Avatar
You forgot the most important one...
While I'm In There
Who Will Live... Will See
Old 10-23-2014, 10:06 AM
