1987Porsche Carrera E-Brake
My e-Brake light will not go off after I release the handle, Any ideas to cure this issue?
Old 08-19-2012, 09:09 PM
Amochosto's Avatar
Mine too, when I release it the light remains on, then I press the button again, it goes down one detent and the light goes off.
1984 ROW 911 Carrera Pacific Blue Metallic Practically no options other than sunroof and custom paint.
2009 BMW E90 M3 Interlagos Blue
Old 08-19-2012, 09:48 PM
twistoffat's Avatar
Mine is the same. I keep the button pressed and drop the lever to the very bottom and then it goes off. If its not all the way down to the last millimetre it can stay on
Old 08-19-2012, 10:34 PM
Dave Colangelo's Avatar
There is a small switch that controls this light. If im reading the part diagram correctly it is part number 901 613 521 20, it is a small contact that the back of the E-break handle rubs against. Dont remember if its NO or NC but any how it is most likely dirty or obstructed. The one on my 78 was cracked when I opened my E-Brake to deal with some other things, I find no use for the light so I just pulled the piece and forgot about it. To clean it or replace it you will need to remove the E-brake handle and take the assembly apart. Be careful when you do this, the yoke that the two E-Brake cables connect to can be difficult to get back on when putting the assembly back together.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 08-19-2012, 10:35 PM
na2ub's Avatar
Check your brake fluid too. Not sure on your year, but the low fluid sensor lights the same light.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 08-20-2012, 08:18 AM
The Dude abides...
bigel's Avatar
Same here...every time I release the brake it takes one more push of the button to release to the bottom...and my brake fluid level is fine.
'03 Carrera 4S
Old 08-20-2012, 09:25 AM
