Output signal from Oil temp and pressure sensor
Hi If possible i want to use my innovate auxbox to log signal from the original oil pressure and temp sensor on my 930.
Does anyone know what kind of and what range the output signals are? Thanks Rune |
AFIK it depends on the gauge/sender. Go to a VDO site, type in the part number and it should give you the specs.
I used "EGauges". Do a Google on them.... |
| All times are GMT -8. The time now is 06:55 PM. |
