-   -   headlight switch retaining nut (http://forums.pelicanparts.com/porsche-911-technical-forum/585711-headlight-switch-retaining-nut.html)
brown911 01-15-2011 03:03 PM
Hi, I'm after a new headlight switch retaining nut (the one requiring circlip pliers to remove). I have searched through the pelican parts catalogue but have been unable to locate it :confused:. Would someone please be able to provide a part number or link if available.
Thanks.
86 911 Targa 01-15-2011 03:59 PM
Thanks.
Anything for the folks "Down Under".
You owe me a Crown Lager!
Cheers,
Gerry
http://forums.pelicanparts.com/uploa...1295139506.jpg
brown911 01-16-2011 01:42 PM
Thanks for the the parts diagram, I'll have the crown lager on your behalf:D
Looks like pelican do not have these switch nuts, does anybody know of a source for new ones?
Cheers
javadog 01-16-2011 01:59 PM
Try entering the part number in the search box at the top, left side of this screen. I'm pretty sure they can get them, as can any Porsche dealer.
JR
86 911 Targa 01-16-2011 02:47 PM
Cheers
If this is what you are looking for,
I saved this one when I replaced
the headlight switch in our '86.
If not available from your local P-Dealer,
pm me with your address, and you can have it.
Now, about that Crown Lager................
Cheers,
Gerry
http://forums.pelicanparts.com/uploa...1295221330.jpg
http://forums.pelicanparts.com/uploa...1295221618.jpg
http://forums.pelicanparts.com/uploa...1295221370.jpg
KNS 01-16-2011 05:38 PM
If it's the same one I'm thinking of I used the little knurled nut off of a presta vlave on my bicycle, the threads are identical. It is the little nut that holds the valve for your inner tube close against the rim, most people just toss 'em.
brown911 01-18-2011 09:50 AM
Cheers,
Gerry
Hi Gerry
PM sent
porschedude996 05-23-2022 06:19 PM
I had a split nut for the headlight switch. I purchased a version that was available and cut the nut to lenght and threaded the hole. The unthreaded blank hole was marginal almost marginal. It tap doesn’t give you 100% thread, but the stress isn’t that high.
Cheers,
Gerry
http://forums.pelicanparts.com/uploa...1653358602.jpg
