-   -   Spring PLate bushing replacement G50..anyone done it? (http://forums.pelicanparts.com/porsche-911-technical-forum/585792-spring-plate-bushing-replacement-g50-anyone-done.html)
Hodgey 01-16-2011 06:59 AM
Hello.
Getting ready to do the bushing change on the rear spring plates and I'm wondering how far out the torsion bars come into the housing? From a previous thread pic (below) that I posted you can see the length of the housing for my G50, and there is a subtle change in diameter at the tip.
If the TB comes this far out, how am I going to get the spring plate off the TB and out of the vehicle? I know I have to take the blanking disc off the body to allow the tube to come out through it but still....:confused:
Does the end of the tube come off for access to the outboard end of the torsion bar or is a case of fiddling with the orientation of the tube until I can get it off and around the TB and off the car?
http://forums.pelicanparts.com/uploa...1295189928.jpg
Thanks in advance for any pointers..
Neil
john walker's workshop 01-16-2011 07:35 AM
there'a room. no need to pop off the outer disc. the rocker and the hole cover come off, of course. the torsion bar just needs to be all the way in.
88911coupe 10-14-2011 11:32 AM
So does this end up ruining the gravel guard or whatever that black thick decal is on the side just covering this area?
89911 10-14-2011 01:15 PM
In short, yes. If your handy you can carefully cut it out.
88911coupe 10-14-2011 01:38 PM
Thanks...I'm about as handy as a monkey with a ball peen hammer. Looks like I'll be buying new ones...
ivath 10-14-2011 02:51 PM
Its possible to carefully remove the torsion bar covers from the Stone guards. You can glue them together again when you are finished. Worked for me.
