-   -   What happens if you have worn out valve guides but new stem seals? (http://forums.pelicanparts.com/porsche-911-technical-forum/585994-what-happens-if-you-have-worn-out-valve-guides-but-new-stem-seals.html)
930cab89 01-17-2011 06:04 AM
My winter project was (is) to change the valve stem seals as the engine was using a more than normal quantity of oil and I supposed (rightly) that these seals had never be changed before. I also wanted to get an idea of what has to be done in the next future to this engine.
When changing the seals, I noticed that some valves had some free play that indicates some worn guides. As the money is not there for the moment, I changed my seals as foreseen and am now reassembling the whole engine. I was just wondering what this will mean for my engine? I suppose that the oil consumption will be gone (more or less), the new seals sealing of the space between the guides and the valves even if the valves move a little bit inside the guides.
Is this correct or not? What else to expect?
Rot 911 01-17-2011 06:13 AM
What happens when a valve guide gets loose and you lose heat transfer:
http://forums.pelicanparts.com/uploa...1245071295.jpg
LakeCleElum 01-17-2011 09:03 AM
I think one of Bruce Andersons books say what Kurt told you: You lose the ability to transfer heat from the valve to the head. Worst case, head of valve breaks off and does major damage to the engine. If you can feel the play, it's pretty excessive. Measure with a dial indicator.....With the labor involved, I'd do it right the first time?
john walker's workshop 01-17-2011 09:18 AM
guides tend to wear more at the valve head end. so if there is slop at the spring end, there will be even more at the other end. valve stems wear also. they get tapered consideraby.
brads911sc 01-17-2011 09:29 AM
Probably worth saving the money to just have it done. Dont want a $1500 top end to become a $5500 top end when you destroy a couple pistons/heads...
where you located?
4sd911 01-17-2011 09:40 AM
Oil consumption can be from a few places and if excessive you should see it on the plugs. I understand turbo seals go bad and start to suck oil. If you still have the springs of the valves see how much they move side to side.
930cab89 01-17-2011 10:33 AM
You're scaring me guys !
TT Oversteer 01-17-2011 12:15 PM
Don't want to rain on your parade here but I changed my valve guide seals on my 3.2 in an attempt to defer replacing guides for a couple years. The result, in my opinion, was not worth the effort.
I replaced my seals with the engine in the car and only removed the valve springs and keepers. If you already have the heads off I would DEFINITELY do a valve job before reassembly. The money you "save" by not doing the valve job now is not worth the labor involved in doing the job over again.
When all was done on my job, I was out only the price of the seals and the three specialized tools needed to remove the springs and seals. So..........$200 and two days later...........oil consumption went from 1qt/600 mi. to 1qt/800 mi.
Just take your time and do it right is my advice.........sorry!
Rodsrsr 01-17-2011 12:26 PM
Is this correct or not? What else to expect?[/QUOTE]
Life ceases to exist as we know it..... Sorry I couldnt resist. SmileWavy
Seriously though, I just did a top end rebuild on my 3.2 so I know what your going through. Its too big of a job to not do correctly the first time. If there is side play then more than likely the guides need to be changed and valves checked as they could be worn as well.
Steve@Rennsport 01-17-2011 01:31 PM
If this is a Turbo motor, I would park it until you can do the job properly otherwise it has the potential to get FAR more expensive.
930cab89 01-27-2011 11:57 PM
I've listened to all the advice and decided to change the guides and valves and do everything properly. Thanks.
