1969 gauge issue
I have read all of the threads I can find on pelican regarding removal and dismantling of the gauges. All very helpful EXCEPT...am I crazy or does my 1969 911e come with gauges that are different in the way they are assembled than the newer ones in the how too's.
I cannot seem to remove the glass bezel from the gauge body.
I am referring to the gas/oil gauge. I have it totally apart except the glass. My little silver middle button fell off and I cannot put it back with out removing the glass bezel plus I would like to clean the glass.
This bezel does not seem to be crimped on like the newer ones (I have an 84 also and it is not the same). I cannot even fit a razor blade btwn the black bezel ring and the gauge body. Threads recommend a screwdriver???
Is it glued or made to not come apart?
Your help is appreciated.
Old 01-19-2011, 04:49 PM
Nobody...
Old 01-20-2011, 05:25 PM
Can you post a photo? I have a 69 and a 73 and both have bezels on the gauges that can be pried up to remove the glass. The fact you cannot fit a razor blade between the gauge body and bezel lip sounds unusual. A picture would certainly get some responses.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-20-2011, 05:37 PM
Thanks for the response. I should have taken pics. I managed to clean the glass and re glue the button without removing the glass. It was no picnic though. I may try to clean the other gauges and will post pics if I run into the same issue.
Old 01-21-2011, 04:18 AM
Been here a while
agreed, a photo would help a lot....I've got a few of the gauges out of my '69 S, and the construction is typical VDO, uncrimp the ring, pop glass off, clean, replace seal and bezel and reinstall.
Lewis
looking for 1972 911t motor XR584, S/N 6121622
Old 01-21-2011, 05:59 AM
