Danny_Ocean's Avatar
Can you braze header tubes?
I've got a very slight separation in the weld on my cat bypass pipe. It is not much bigger than a hair...not a crack, but seems the weld just didn't "stick" in this area. I don't want to remove the pipe from my car if I don't have to.
Using the appropriate rod (bronze/brass?) and oxy/acetelyne, can I braze this gap?
Old 01-19-2011, 01:54 PM
I d take it to a muffler shop and have them MIG it. If you put heat flame on it, it could warp the pipe
Bruce
Old 01-19-2011, 02:08 PM
Bruce
MIG won't burn through? (The other issue I have is the car is lower than a gnat's azz, so I'm not sure it could be lifted at your local muffler shop).
Old 01-19-2011, 02:24 PM
RETIRED
Joe Bob's Avatar
Shouldn't be an issue if he has an old school open pit. Wire fed with argon shielding gas would be a snap.....
Old 01-19-2011, 02:41 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Take it off and have it properly welded. TIG, everything else is half way. It would take a good TIG guy about 3 minutes, of which 2 would be set up. If it is aluminized all bets are off. Is it leaking?
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-19-2011, 02:44 PM
It's barely leaking. You can see some carbon at the joint (which is how I discovered it).
I own a MIG machine...but don't know how to use it. The neighboring shop are welders. Perhaps I can have them use my machine on it (or run an extension cord from their shop). There is a guy there who knows how to TIG, but he's barely around and isn't very reliable. Don't want to deal with him if I don't have to.
Old 01-19-2011, 04:06 PM
porsher
aston@ultrasw.c's Avatar
I suspect the flange is significantly thicker than the tube, this makes it a difficult weld. Too much heat and you burn holes in the tube, not enough and you get pigeon **** (technical term) on the flange.
A braze would be an acceptable repair. All you need is a seal, the strength comes from the weld. Assuming the rest of the weld is up to scratch.
A brazed joint needs to be prepped carefully. It must be completely free of oxide, paint, grease etc. Get in there with a grinder and open it up a bit, wash out with acetone etc... Then brush flux onto the joint, don't just dip the rod and braze away.
It could be repaired with mig, tig, O/A whatever, it just takes more skill and experience. Brazing is a simpler, low risk choice.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-20-2011, 07:45 AM
Registered Abuser
MT930's Avatar
eric
TIG is the right way, a good TIG fab guy could do it on the car in 5 mins.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 01-20-2011, 07:51 AM
Friend of Warren
Back in the day we used to just close those gaps up using oxy/acy and a piece of coat hanger for filler!
Kurt V
Old 01-20-2011, 08:03 AM
Like Rot 911 says you can close that gap with an oxy/acy. It is not that difficult. TIG is overkill for that task. Actually most shops use MIG.
Old 01-20-2011, 11:21 AM
Canuck_Targa's Avatar
If you have a mig in your shop, just see if one of the neighbors could come over and weld it. Wire brush it off (that looks like high heat silver paint) to clean it up before he does it. You won't burn through the pipe (if the guy knows how to adjust his welder).
There is no need to TIG weld repair a MIG welded part, the original weld is mig so repair it with mig.
Unhook your battery before he welds it, so you don't get any current spikes through the cars electrical.
Old 01-20-2011, 12:52 PM
Also have them attach the ground on the piece itself if possible or as near as possible, good call on pulling the battery cables to protect electronics.
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 01-20-2011, 01:11 PM
