-   -   who's running an AFR gauge? (http://forums.pelicanparts.com/porsche-911-technical-forum/587210-whos-running-afr-gauge.html)
haycait911 01-22-2011 12:14 PM
thinking I'll run an AFR gauge with the new engine. this one:
AEM Analog Wideband Air/Fuel Gauge / 30-5130 - eBay (item 270542058221 end time Jan-29-11 14:02:33 PST)
mostly because it's a decent quality and won't look too out-of-place in a '67. I might do two, one for each bank. or maybe I can figure out how to have two senders and switch the input to one gauge. anyone had any experience with an AFR gauge? thanks, Don.
moneymanager 01-22-2011 12:19 PM
A search will turn up several threads on this topic.
Dave 86 930 Fl 01-22-2011 12:20 PM
Innovate
I have the Innovate and have been very happy ... Key to a good install is making sure grounds are adequate.
Regards, Dave
KTL 01-22-2011 12:25 PM
I have that exact one on the '79 (3.0L w/Weber 46s) and it works great. Use it to dial in my A/F since I had to re-jet due to the carbs being tuned for 110 octane. However i'd recommend the digital version for at-a-glance visibility at speed. Still, the analog one works well.
I vaguely recall AEM makes a harness adapter that you can buy to join two O2 signals? Check out their website to confirm.
They recommend these not be used for continual operation at very high EGT temps. So once mine's dialed in, i'll pull the wideband O2 out and plug the exhaust. Wideband O2 sensors are fairly expensive so I see no reason to kill it running WOT on the track all the time. I'll just put it back in on occasion for a periodic check.
jwasbury 01-22-2011 12:33 PM
I also run an innovate system.
LC-1 wideband AFR with permanently mounted gauge and a DL-32 for datalogging of AFR, RPM, MAP, acceleration/braking g's, and cylinder head temp.
http://asbury.smugmug.com/By-Land/My...89_YDd4t-L.jpg
http://asbury.smugmug.com/By-Land/My...09_DJGg8-L.jpg
Interfaces with my UMPC to form a "digital dashboard"
http://asbury.smugmug.com/By-Land/My...99_Sbgqw-L.jpg
don gilbert 01-22-2011 12:49 PM
http://forums.pelicanparts.com/uploa...1295729302.jpg
I like the inovate. I have an adjustable wur so it is a must. Makes for easy tuning to.
cgarr 01-22-2011 01:29 PM
Here is there new one I am thinking of getting:
MTX-L Wideband O2 Digital Air/fuel Ratio Gauge
haycait911 01-22-2011 01:44 PM
I really like the gauge pod in the ashtray hole. I'll do that. also the voltmeter, I've missed having one since the 914.
jclotz 01-22-2011 03:06 PM
I had a custom gage built for the clock that interfaces with an LC-1. Have two O2 sensors (L&R) and a switch that can toggle between the two.http://forums.pelicanparts.com/uploa...1295737569.jpg
LJ851 01-22-2011 03:12 PM
Ive run a wideband 02 sensor in my cars for years for tuning . I cant imagine going back to guessing AFRs! I want to recommend an analog gauge . If you are trying to tune injection or carbs digitally
with poor drivability during quick throttle motion, it is very hard to tell what is happening when all the digital numbers are changing so rapidly. With the analog gauge the needle sweep tells you a very accurate story.
haycait911 01-22-2011 03:48 PM
EXACTLY what I need! even the switching. can you tell me where you got it, and about how much it was? thanks.
jclotz 01-22-2011 03:54 PM
I had the gage done by BigMark Design (bigmarkdesign@aol.com). I sent him my core and he provided the rest. I think it was about $200. Actually, I used an LC-1 that allows some programming to get the analog gage calibrated. I bought a vintage-looking switch from Radioshack and mounted it in a pre-existing hole in the dash under the speedo. I think this hole was there for a fog light switch.
It really has been a BIG help when trying to dial-in the Webers.
Hope that helps.
http://forums.pelicanparts.com/uploa...1295740448.jpg
dicklague 01-22-2011 04:09 PM
I have been using a good AFR gauge on my 1973 2.7L MFI engine for more than a year. Did lots of research before I bought. In my opinion the Innovate is a 5+ year old design that is expensive and difficult to hook up. I went in a different direction and have been very happy.
My choice was the Daytona-Sensors WEGO IV. The major advantage is that it is a small all in one unit that has 2 hours of data logging. You download the data and look at the charts using the supplied software. Or you can download in an Excel spreadsheet and study the numbers on the spread sheet.
In addition to AFR, you hook it up to the tach wire on the 911 so you can see RPM, AFR, and mine has a MAP sensor so I can see manifold vacuum.
DATA LOGGING IS VERY IMPORTANT! I can't say enough about this. You do a good run, and study the data and make adjustments. Looking at the gauge while you drive is not the way to go. Trust me.
You can get data logging on the Innovate and others, but it is usually a very expensive add-on.
http://forums.pelicanparts.com/uploa...1295741100.jpg
This is the unit and the sensor. Kit comes complete with cable, bung, software and full instructions.
They also make a double unit that looks like this:
http://forums.pelicanparts.com/uploa...1295741198.jpg
This comes with 2 sensors and 2 readouts and data logging for both.
Programming and downloading are done with a USB cable to a laptop.
The single unit is a little over $400.00 USD and is sold by our hosts.
I would seriously look at this unit. I am very happy with it. Very reliable, easy to install and data logging is a must.\
Here is the full kit contents.
http://forums.pelicanparts.com/uploa...1295741372.jpg
dicklague 01-22-2011 04:12 PM
By the way it is made in the USA in Daytona Florida. I noticed the USB cable in the kit has a made in China on the packaging. This is a USA made unit. check out the website Daytona Sensors LLC - Engine Controls and Instrumentation Systems for Automotive and Motorcycle Applications for more information and you can even download the software if you want to check it out.
kav 07-03-2021 10:04 AM
Hope that helps.
I’m looking to do the same. Wondering how the switch works? Do you use two wideband controllers and the switch goes between them? Which model controllers do you use?
Any info
Cheers
-Kav
jclotz 07-03-2021 10:28 AM
Yes, used a two position switch between two LC-1s and the gage. They shared a common ground snd the signal was switched.
chrismorse 07-03-2021 12:17 PM
Many points to consider,,
Ergonomics, (how easy is it to see, when you are testing - higher is better)
Compatibility, can i run it full time from the canbus on the megasquirt?? The MS has good data logging capability but will it run a gauge full time also??
How helpfull is dual sensor input/cost???
It seems that an analog gauge might be more user friendly than rapidly changing digital display, But?? Experience??? obviously, data logging makes this question moot.
Cost to add to a MS EFI??
Lastly, appearance, does it look OE, like the slick clock replacement with volts/O2?
Obviously, I'm not asking my wife, who subordinates function, ergonomics, cost, durability, repairability, compatibility and everything else to "How it looks" - sorry, slipped off my meds there for a moment.
chris
kav 07-06-2021 08:28 AM
Great thanks! I thinking of running 2 AEM 30-0310 wideband controllers, any thoughts on that? I've heard the LC-1 connectors can be temperamental?
Cheers
-Kav.
911pcars 07-08-2021 11:28 AM
Did you rewire to also provide current to both sensor heating circuits? Heating current must be maintained anytime the sensor is exposed to exhaust gases, otherwise sensor life is shortened. Switching only the active gauge wires cuts off needed heater current to the "OFF" (idle) sensor. From my limited search, it's not a straightforward process.
This issue was discussed here earlier this year:
http://forums.pelicanparts.com/porsche-911-technical-forum/1045024-two-sensors-one-af-gauge.html
Sherwood
tops911 07-08-2021 12:55 PM
I have one from a Pelican member who installed the gauge in the tachomemter, replacing the boost gauge. I have a boost gauge in the clock position anyway. I think it was called "In your Face". It's a PLX gauge, I really like it
tdw28210 07-09-2021 06:35 AM
Got one in the turbo. The car is a bit of an outlaw with a modified interior. The PO put it on the lower left ,near the ignition. It comes in handy and is comforting to see, BUT if I was choosing I'd likely get this one from Summit Racing. Not an exact match with the gauges, but pretty good for off the shelf.
https://static.summitracing.com/glob...4191-01_xl.jpg
cmcfaul 07-09-2021 04:20 PM
In my 73 E I mounted into the cigarette lighter. Looked fine, was easily readable and was easily stashed in the glove box when not needed.
Fabed it from a cut off screwdriver handle that fit the cigarette lighter well and attached the other end to the gauge.
No permanent changes to the car.
Chris
73 E
89 Carrera
47silver 07-09-2021 04:27 PM
I use 2 in the 72mfi seems to work good
