-   -   Help: Test Power to DME (http://forums.pelicanparts.com/porsche-911-technical-forum/587242-help-test-power-dme.html)
Srwilliams 01-22-2011 02:22 PM
I have done something dumb. I was hooking up wires to my headlights and foglights with no problem, all while starting the car to make sure I was hooking up the correct wires. I must have started the car 15 times throughout this process with absolutely no problem.
Then out of the blue the car stopped firing. I mean it keeps cranking without starting. I checked and I am not getting any spark to the coil whatsoever and the fuel pump is not coming on. I cannot hear it clicking on when the car is trying to start.
I changed the coil as well as the dme relay. Still no spark to the engine and the fuel pump is not activated. I am now trying to troubleshoot.
It is my understanding that I need to first check to see if I have power coming into the DME and then going out of the DME. Can anyone explain to me in simple terms how to do this. I have a 1987 carrera. I took the seat out of the car and I am prepared to test the power at the DME. I just do not know what pins to check or how to go about checking the power source to and from the DME
Any help would be greatly appreciated.
LJ851 01-22-2011 06:31 PM
If you have a factory alarm system, it could be acting up. The power for your DME relay goes through the alarm brain.
Srwilliams 01-22-2011 07:38 PM
LJ851:
Thanks for the reply. I ruled out the factory alarm. Years ago I disengaged the factory alarm and so it is inoperable
DRACO A5OG 01-22-2011 09:12 PM
oh man, sound like the reference sensor.
get your DVM out and check the OHMs on both speed and reference sensor
kidrock 01-23-2011 10:41 AM
Here's a very helpful thread on testing the DME unit, as well as the speed and reference sensors.
http://forums.pelicanparts.com/porsche-911-technical-forum/573338-another-84-wont-start-quandry.html
good luck, and please keep us posted.
Srwilliams 01-24-2011 09:12 AM
Kidrock:
Thanks for the site. went to it and read it and it gave me the exact diagnostic check that I needed.
