Fuel pump relays? R they suppose to click?
Hey all, I have been noticing that the red fuel pump relays have been a little noiser than usual. Is this the norm or do I have a fuel pump or relay problem? This is on a 1986 930 Turbo
RJ Gilliam 1986 930 Turbo "Julie" |
They should click only when you turn the engine on and off. Otherwise they shouldn't make noise.
Bill Krause We don't wonder where we're going or remember where we've been. |
Replace or fuel pump issue?
It could be either, or corrosion somewhere in your wiring. It never hurts to have a spare fuel pump relay. Start with the cheap stuff.
Thanks very much, I have already replace the fuse block because of "heat" I will replace the relay this weekend to see if it takes care of it.
Thanks for the advice, RJ Gilliam 1986 930 Turbo "Julie" |
