-   -   Who can make me canards (dive planes) for a 70 RS Clone? (http://forums.pelicanparts.com/porsche-911-technical-forum/587478-who-can-make-me-canards-dive-planes-70-rs-clone.html)
minoclan 01-23-2011 05:23 PM
I haven't had any luck finding any online. I don't want to spend a fortune. My current obsession is downforce, or in my case minimizing lift. Does anyone have a source that they can share with me?
Flieger 01-23-2011 05:33 PM
What does your aero setup currently consist of? A bigger splitter is nearly "free" downforce- no extra drag, just using the existing high pressure area. Dive planes are usually very inefficient, working at high angles. They also affect the flow over the rest of the car, but the wheels will already cause a disturbed airflow in their wake.
tcar 01-23-2011 05:57 PM
What he said... You want splitter enhancement...
minoclan 01-23-2011 07:07 PM
I have the TRE splitter. I am putting on the IROC rear spoiler.
Flieger 01-23-2011 09:13 PM
Make the splitter bigger. :)
Maybe vent the oil cooler through the hood?
Noah930 01-23-2011 09:23 PM
Steve Wong has an interesting idea on his 911. He has some sort of splitter/spoiler (can't recall which) but because he didn't want to make it too low, for curb clearance issues, he fabbed a flexible piece that extends downward like a curtain from the aft portion of the splitter. The extension can bend if he hits a bump, and is "sacrificial" compared to the rest of the (hard) splitter. It still does the same job of diverting air from passing under the car, though.
Flieger 01-23-2011 09:28 PM
But the splitter adds downforce by having its upper surface area exposed to high pressure (from an air dam or the front of the car). An air dam below a splitter reduces downforce.
Noah930 01-23-2011 09:35 PM
Which is why I think it's a spoiler extension he has, not necessarily a splitter. I think it's on his Carrera, not the GT3.
Jack Olsen 01-23-2011 11:53 PM
(I'm reposting this from a couple of years back.)
I made a set of these, initially thinking they functioned like little wings to generate downforce at the front of the car. The part I didn't understand was why they were usually set at such steep angles of attack -- it seemed like they'd have to be well beyond the point where a wing would basically stall.
Here are mine are in a photograph taken at speed:
http://forums.pelicanparts.com/uploa...1161555581.jpg
As it was explained to me, winglets/canards/diveplanes aren't functioning as wings at all. They're vortex generators, and functionally they have less in common with wings than they do with the fans above open grocery store freezers. They generate swirling air along the sides of the car, most importantly down along the space between the track surface and the rocker panels. Their function is to stop air from getting under the car along its sides. This basically means (at least as far as my non-engineer's brain can get around it) that low-pressure air under the car doesn't suck air in from below the doors.
Here's a useful illustration from the Suzuka Racing site:
http://www.suzukaracing.com/Aerodyna...LipVortex3.jpg
And here's a more succinct explanation from a Pelicanite in a previous thread:
Originally posted by BertBeagle
These are/were used on ground effects cars (ie the IMSA GTP cars of the 80's). What they accomplish is creating a vortex down the side of the car, filling the low pressure area that exists along the sides of the car, and that kept the air entering the underside of the car from the nose under the car and effectively increased the down force with a low drag penalty. Aero guys are always looking for something for nothing (ie downforce for no drag penalty) and this was a good find.
My guess would be that they improve downforce/grip at both the front and rear of the car, since they're essentially a component of underbody air management. But like other guys in this thread, I felt the effect as a better planted nose when I added mine.
Flieger 01-23-2011 11:59 PM
Whenever Racecar Engineering does an Aerobytes section involving dive planes, they always say that they are rather inefficient from a negative lif to drag perspective. I seem to recall them saying this with the prototypes, not just the GT cars, suggesting they are stalling, perhaps just piling up air on the splitter? The turbulence behind them should just be adding to the turbulence from the wheels, so they should not really be adding turbulence where there was laminar flow before.
There is a reason why most ALMS-type racing teams remove some, if not all, dive planes for LeMans.
Jack, I like the looks of your shallower ones better. It looks lke being that close to the underside of the bumper might give them a bit of splitter effect, in that the air pressure is increasing as it compresses between the dive plane and the underside of the bumper, then pushing down on the top surface of the dive plane. It would sort of be like moving the splitter up by 6 inches.
5:04 01-24-2011 12:20 AM
Like usual Jack and Fleiger are right :D
Many people that use them without knowing their real effect, however for most people they seem to work. Fleiger is right though in saying that they create a lot of drag and don't directly provide downforce. I'll be testing a couple of very big canards on my car in the next couple of months once I get my wing and finish my aero package so I'll see if they gain or lose time and try to post some numbers with various aero parts added and removed with lap times to back them up.
From my understanding, Canards are a fine tuning aero item and also help by diverting air away from the tires which helps with that planted feel that Jack and many others have felt.
Cars that have lots of trick aero often have giant Canards that work with very low side skirts. I've even seen cars run the garage lining on their side skirts all the way to the ground to try and keep air from under their car.
Here is a picture of a very fast Miata with an extended airdam covering the tires and the aforementioned lining. The Canards will often provide this effect inadvertently and people will comment on a difference.
http://forums.pelicanparts.com/uploa...1295857040.jpg
Also if you want them to make the biggest effect they have to be big i.e. the Cyber or Sierra Sierra Evo.
http://forums.pelicanparts.com/uploa...1295857163.jpg
minoclan 01-24-2011 05:01 AM
Jack-
I also found that taping over the horn grills stopped a significant amount of air from coming in the front and giving me lift. I didn't think that it would make a tremendous difference, but it did.
Mahler9th 01-24-2011 10:13 AM
If you decide they can help in your situation, you can easily make them yourself with aluminum, fiberglass, carbon fiber, et cetera. I have made several different types for my car, which has a Getty Design 993 G-style front bumper.
I use some really big ones at Sears Point, and they help the balance for my car quite a bit there. That is the only place I run the big ones.
http://forums.pelicanparts.com/porsche-autocross-track-racing/394212-anyone-using-canards.html
See this thread... and I'd be happy to describe how I did it if there is interest. I also have some additional pictures.
Mahler9th 01-24-2011 10:15 AM
Also check out Sierra Composites:
Carbon Fiber Sheets Panel Sandwich Panels Angle Tubing Basalt sheets Texalium sheets
911pcars 01-24-2011 10:23 AM
One can try to copy aero devices on other car brands or take an existing aero theory and try to apply it to your car. However, unless you can test air flow via a wind tunnel or use pre-wind tunnel testing procedures (see Jack's airflow test thread), then it's all a guess - unless you're doing it for looks.
Whatever the factory did usually works (except for no wings on the 917). A good guide would be to study Porsche's aero device chronology on their track cars.
Sherwood
minoclan 01-24-2011 10:31 AM
Sherwood
I'm not doing it for looks. I unfortunately don't have the budget for a wind tunnel. This is "seat of the pants".
Mahler9th 01-24-2011 10:46 AM
Seat of the pants can work, if you have a good seat. Whether a particular effort toward solving a particular problem or optimizing some aspect of performance is a waste of time depends on way too many variables to discuss here. But one needn't use a wind tunnel or even do tuft testing in certain situations. The answer is like always... it depends.
JeremyD 01-24-2011 10:57 AM
Have you had your a$$ calibrated? You need to do that every three years to maintain your certification.
SC Aero GT3 race carbon fiber front dive planes / canards
http://www.sierracomposites.com/v/vs.../SCGT3DP-2.jpg
minoclan 01-24-2011 11:22 AM
Saw those, thanks
Mahler9th 01-24-2011 11:27 AM
One of my friends bought a set of those for his race car. Nicely made but very small for a 911 nose (his is 934). So likely difficult to feel a difference. There are lots of parts out there in the import car scene... most are pretty small.
Flieger 01-24-2011 04:47 PM
Notice that the "flicks" have gotten much larger from 2007 to 2010:
<a href="http://www.flickr.com/photos/max_911_fahrer/3095738245/" title="ALMS LBGP 4.14.2007 Bergmeister 997 RSR by Max_911_fahrer, on Flickr"><img src="http://farm4.static.flickr.com/3272/3095738245_5504aae8cd.jpg" width="500" height="375" alt="ALMS LBGP 4.14.2007 Bergmeister 997 RSR" /></a>
2010:
<a href="http://www.flickr.com/photos/max_911_fahrer/4532616593/" title="Long Beach Sports Car Racing 2010_Part 1 040 by Max_911_fahrer, on Flickr"><img src="http://farm5.static.flickr.com/4052/4532616593_88d563d313.jpg" width="500" height="375" alt="Long Beach Sports Car Racing 2010_Part 1 040" /></a>
<a href="http://www.flickr.com/photos/max_911_fahrer/3458791588/" title="Long Beach Sportscar Races 2009_084 by Max_911_fahrer, on Flickr"><img src="http://farm4.static.flickr.com/3551/3458791588_4e60d4cf4c_z.jpg" width="640" height="480" alt="Long Beach Sportscar Races 2009_084" /></a>
<a href="http://www.flickr.com/photos/max_911_fahrer/3458790986/" title="Long Beach Sportscar Races 2009_082 by Max_911_fahrer, on Flickr"><img src="http://farm4.static.flickr.com/3510/3458790986_0ff777528b_z.jpg" width="640" height="480" alt="Long Beach Sportscar Races 2009_082" /></a>
<a href="http://www.flickr.com/photos/max_911_fahrer/3095736269/" title="ALMS LBGP 4.14.2007 9R6 gills by Max_911_fahrer, on Flickr"><img src="http://farm4.static.flickr.com/3112/3095736269_560202ef8c_z.jpg" width="480" height="640" alt="ALMS LBGP 4.14.2007 9R6 gills" /></a>
This one has two curved profiles joined together:
<a href="http://www.flickr.com/photos/max_911_fahrer/3095769505/" title="ALMS Long Beach 4.19.2008_ 9R6 nose by Max_911_fahrer, on Flickr"><img src="http://farm4.static.flickr.com/3175/3095769505_fb9e6ea709.jpg" width="500" height="375" alt="ALMS Long Beach 4.19.2008_ 9R6 nose" /></a>
<a href="http://www.flickr.com/photos/max_911_fahrer/3095777979/" title="ALMS Long Beach 4.19.2008_0133 by Max_911_fahrer, on Flickr"><img src="http://farm4.static.flickr.com/3291/3095777979_22083ebae2.jpg" width="375" height="500" alt="ALMS Long Beach 4.19.2008_0133" /></a>
minoclan 01-26-2011 04:15 AM
TRE is going to custom make me a set. Thanks Dave.
empire0007 03-30-2011 11:56 PM
Mike wrote:
I would like to see how it came out. I am interested as well. Maybe he can make me one as well.
BoxsterGT 01-20-2012 01:04 PM
Its been a while, any news on these?
Len
911pcars 01-20-2012 01:43 PM
Nothing you can adapt for the versions sold for the import scene? I'd think a vendor would be happy to know there's another application for this product.
S
KTL 01-20-2012 02:17 PM
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Try to see where this guy got these? Perfect addition to those who have the IROC front bumper.
dfhtrhjn 01-20-2012 02:42 PM
I may have missed the point a little but I just use one of these bumpers instead for a tittle extra downforce. It's like the rs bumper but with an extended splitter. Seems to keep the nose down alright...
www.Rennspd.Com
minoclan 01-20-2012 02:47 PM
Len
Never got them. A few promises but no deliveries.:(
empire0007 05-02-2012 08:11 PM
i wanted to follow up with the Canards and see if anyone got a hold of any and if so any pictures?
retro356 03-13-2013 07:51 PM
Just finished a set for my 914. Only one installed today.
http://forums.pelicanparts.com/uploa...1363228978.jpg
http://forums.pelicanparts.com/uploa...1363229176.jpg
http://forums.pelicanparts.com/uploa...1363229212.jpg
ZAMIRZ 03-13-2013 08:00 PM
Can someone explain what's going on here and what the difference is? I took this pic of a 962 in Monterey '09. The cannard is mounted on the front of the car, i.e. not allowing airflow to start moving around the sides of the car...??? Doesn't this increase the frontal area?
http://i271.photobucket.com/albums/j...62-profile.jpg
