Twin Plug Electrical Question
I am about to convert to Twin Plug... at same time PMO's along with Hi-Rev Cams etc... I just noticed that MSD Set up has a limit of 6k RPM (Unless I have that wrong!!!)... What electrical set up is worth using?
Old 01-24-2011, 12:54 PM
Carrerax's Avatar
The MSD is fine. in fact 2 MSD's are better. The 6k linit is just a plug in chip in the side. you can amek it whatever you want....that is if it is a 6AL unit.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 01-24-2011, 12:59 PM
Got you, Thanks
Old 01-24-2011, 01:02 PM
AutoBahned
RWebb's Avatar
be aware that those plug in resistors that msd gives you are not very accurate - I diagnosed a "misfire" to the improper pill causing a lower than it should be ignition cut
Old 01-24-2011, 03:21 PM
