Obsessed
sobamaflyer's Avatar
Inner Door Handle Question
Will the inside slim armrests/handle with pushbutton door opener from a 1970 bolt up to a 75 without major modification?
Thank you, Travis
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 01-25-2011, 03:41 PM
Thank you, Travis
1970 cars had a pull lever opener similar to that on 75 model cars. What you appear to describe is the earlier armrest from 67 and earlier (maybe 68 too) that had a small push button at the front of the armrest. Whether or not the early style will work, I don't know for sure.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-25-2011, 03:57 PM
Obsessed
Here is the image from the For Sale ad here in Pelican, it states it's on a '70 Targa so?
'73 Mercedes 450 SL
Old 01-25-2011, 05:18 PM
I have a 70 911T and a 67 912 doner. The door handle in the 67 is as pictured above, while the 70 has a mechanism that is similar to later models. I would guess that the inner door mechanism is the same, but there may be minor differences with the exterior mechanism.
1970 911 T
2004 Carrera 4S
Old 01-25-2011, 10:21 PM
Obsessed
Did Porsche maintain the mounting locations (the welded in nuts) for the upper & lower portion of the handle?
In that picture it looks farther forward and my guess is that they are probably different?
'73 Mercedes 450 SL
Old 01-26-2011, 02:39 AM
