How can you tell if you have stock or upgraded turbo tie rod ends? I checked the archives and could not find that specifically.
My car seems to have a loose feeling up front and I can feel it crawl over bumps and imperfections in the road - i.e. it does not feel tight. I would like to do this upgrade if it has not been done. Thanks, MichaelW 87 targa |
The turbo tie rod's inner joint is a ball joint, whereas the stock tie rods simply have a pin joint.
Chris B 78 SC |
Hilbilly Deluxe
I had the same question last month. Good answer here:
http://www.pelicanparts.com/ultimate/Forum3/HTML/010245.html Tom ------------------ 82 911SC Coupe |
