-   -   911 specific tools (http://forums.pelicanparts.com/porsche-911-technical-forum/588269-911-specific-tools.html)
obrut 01-27-2011 03:59 PM
911 specific tools
As part of a garage renovation I'm going to get a good quality mechanics tool kit to replace the motley assortment of tools I have collected over the years. The tools will mainly be used for prepping a historic circuit car (69 911E) and a tarmac rally car (911ST clone) for events and also general maintenance/fixes etc.
What 911 specific tools would you recommend adding to a general mechanic's tool kit.
My list so far includes:
- fan belt pulley removal tools (have)
- socket for steering wheel nut (have)
- jacking plug/base (have)
- long socket for wheel nuts on long studs (have)
- breaker bar (have)
- torque wrench (have)
- ratchet spanner for sway bar drop links
- MFI pump tools (have)
What makes your life easier when working on (early) 911's?
equality72521 01-27-2011 04:02 PM
Christian's tool for drilling out broken exhaust studs
dipso 01-27-2011 04:08 PM
Factory spark plug removal tool.
wildcat077 01-27-2011 04:36 PM
Good compressor and quality impact gun along with high speed grinder and a good assortment of rotary bits/cutting discs ...
Propane torch with MAP gas (yellow bottle ) for removing stubborn parts without snapping them !
Good variety of 3/8 drive extensions and 1/2 drive impact sockets,short and long ...
I could go on all night as a man never owns too many tools ... lol
Hope you had a Happy Australia Day !
Cheers :)
Phil
obrut 01-27-2011 04:42 PM
Thanks guys - good stuff. Got the spark plug tool and a few of the other bits mentioned, but wouldn't have thought of the torch.
Phil: Thanks, we had a great Australia Day - showing a bunch of visitors from the UK what sunshine is!
boyt911sc 01-27-2011 05:13 PM
One of my favorite special tool......
Once you tried using this 13-mm special tool, you would likely never going to use the regular box/open wrenches again for your next valve adjustment work. Using the right tool for any job makes the task easier and enjoyable.
http://forums.pelicanparts.com/uploa...1296176721.jpg
Tony
80-911SC 01-27-2011 07:45 PM
I think that a 13 ........
m110 01-28-2011 12:27 AM
Originally Posted by boyt911sc (Post 5811951)
Once you tried using this 10-mm special tool, you would likely never going to use the regular box/open wrenches again for your next valve adjustment work. Using the right tool for any job makes the task easier and enjoyable.
Tony
Where is that available?
Pazuzu 01-28-2011 10:23 AM
Schley Products #88900 <---For 13mm nut
Astro Pneumatics #AP 7819 <---has several sets, including 13mm
Each is about $35-50 online. The Schley products is *probably* a far better built piece.
boyt911sc 01-28-2011 11:04 AM
Correction....
That's right!!! It is a 13-mm. Information corrected and thanks for noticing the typo.
Tony
boyt911sc 01-28-2011 11:12 AM
13-mm valve adjustment tool.......
This is a 'Blue Point' YA8890 13-mm. I bought it from Snap-On tools.
Tony
schumicat 01-28-2011 11:43 AM
large allen head socket to change transmission fluid. can't remember size (17mm???) but you can find it in a search. If your front struts don't have a way to keep the strut from spinning while you turn nut, you need an adjustable spanner wrench (got mine on ebay) to hold the big washer in place (notch on washer) so the strut doesn't spin when you try to remove nut.
