89 rebuild, stay 3.2 or go to 3.4?
I'm having my 89 Targa 3.2 rebuilt. 150k on the clock and a few issues ergo rebuild.
New pistons, cylinders, cams, timing chains and other stuff. I'm already at about 15k. Since I'm already here should I turn it into a 3.4??? Should that cost a bunch more and how much h.p. , torque gain should I get. Is it worth it?? I've used it as a daily driver for the past 5 years and plan to continue to until I forget how to shift. Cheers JR
'89 911 Targa, '11 Audi TTS roadster, '85 Jag XJS (Gone) '2002 Volvo C-70 (Gone). |
Hi John,
having your existing cylinders bored and plated for 98mm JE pistons is a very cost effective way to go. It's definitely cheaper than buying new cylinders.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
You've got to make these decisions as a group (cams, pistons, compression, exhaust, etc), not piecemeal.
As for 3.4, you're considering an expensive 200ccs. You have to decide if you really want the extra displacement at considerable cost. I wouldn't go much above stock compression if you're going to do a lot of touring. If you raise the compression, then race gas is in your future. On the other hand, you did go with the Trident, not the Seawolf, so maybe you're already leaning to the more practical approach.... |
Yes if you are already buying new P&C then go 3.4 no question. Very little cost difference.
If you decide to make it a 3.4, be sure you use the "Max Moritz" wedge-dome pistons otherwise you will need twin-ignition to run on pump gas.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Almost Banned Once
Keep it at 3.2... Stock everything. Except, maybe spend some money on a
Steve Wong chip, a nice set of SSI headers or 993 clam headers and a nice muffler. Monty? Yes it's tempting to add cubic inches but if you want it to last another 150,000 miles then just rebuild it to stock. A well tuned stock 3.2 motor is more than enough for daily duties and is very durable. You can still burn your license in about 30 seconds in either your 3.2 or 3.4. Now if it was a track car??? Entirely different story. ![]() 3.6 or 3.8 conversion with appropriate cams. ($$$$$) And that's just the beginning... "PMO" ITB's, "Motec" engine management, I could go on and on.
- Peter |
MBruns for President
I went 3.4 with my old engine - with the right cams - and a few other tweaks - you can have a great engine.
Remember though - building an engine is like baking a cake. Just adding a bunch of one ingredient does not make a great cake. Specs: Engine Rebuilt top to bottom at 57,000 (6/20/2005) 3.4 mahle 9.8 to one jugs ~ 1MM taken out of pistons for valve pockets Single plug Magnecor Wires Extrude hone intake 993ss cams (Dougherty Racing Cams) ARP rod bolts Supertech Head Studs Enlarged throttle body Competition springs and retainers (EBS) New reference sensors New CHT sensor New fastening hardware New rocker shafts New RSR Rocker Shaft Seals New teflon lined Carrera fuel line New Carrera tensioner lines New oil sensor 993 Flipped Flange Heat Exchangers MK 993 Bischof flange muffler Steve Wong custom chip to pull it all together Dyno tested on Dynojet 248c - adjusted to 244.3 RWHP - so 287 hp at the flywheel corrected. Nice flat torque cruve Yes, I would do it again if I had a 3.2.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I'm here to cause trouble
As a point of reference, you can sell your 89 as is, add 15K to what you get for it, and buy yourself a reallllly nice 993.
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Recreational User
Keepin' it Simple...
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
For $15K you can buy 3 good, used engines. Why not just get a good used one? Would take one Saturday to plug another in.
Tru6 Restoration & Design |
FS: 993 RS look Iris Blue Street/Track It just seems the bang for the buck isn't there spending the extra money on a 3.4. A friend of mine built a 3.4, and it's really nice, no question (smokes me on the track quite handily!), BUT.... it just seems like an awful lot of dough when there may be more interesting alternatives. I guess it comes down to how much you love the REST of the car to invest that much in the engine. JB
Jack
-Jack
85 Carrera Cab |
Thats interesting, I am planning to go to 3.4 and a couple of builders were quoting roughly 15k for 3.4 and 13.5k for 3.2. I was thinking the difference wasn't a lot in the scheme of things. The 3.4 power is wonderful on the ones i have driven.
Personally I would way rather have an impact bumper 911 with a 3.4 or 3.5 than a 993 for the same cost. I think in 10 years the market will also make an excellent 911 with a 3.4 or 3.5 a valuable car. Just like a 911t with a 2.7rs motor has become. |
I'm not knocking a 3.4, not at all. If you were tracking the car, you'd want displacement. If you are going for mile after mile of reliability, you'd want a factory spec imo. The 3.4 Mahle Sports have always been much more than factory 3.2 p&c. I would probably stay with Mahle, but that's only my own .02.
stay 3.2 and spend the extra money on EFI and crankfire.
