A very silly question...
Does motor oil have a shelf life.
I've had this case of Brad Penn for about a year now. Getting ready for the spring oil change. Just checking...
~Max
(Currently recovering from a clutch pedal return spring installation mishap concussion)
1985 BMW 325e - 2 Door
1982 Porsche 911 SC Euro Spec
1965 Land Rover Series IIa Restoration Project
1999 Land Rover Discovery II
2002 Suzuki SV650 Naked Bike
Old 03-21-2011, 07:36 PM
Danny_Ocean's Avatar
There more than likely is a shelf life for motor oil, but it's significantly more than one year.
Old 03-21-2011, 07:38 PM
I'll go out on a limb and say probably not.
If you can run it in an engine for 6 months or a year, with all the chemicals and water getting into it....and it is still doing pretty well, I can't see why sitting in a can would be an issue. There are lots of us out here holding BP for a year or more before use, at least I am.
Old 03-21-2011, 07:42 PM
AutoBahned
RWebb's Avatar
got to be > 5 years; as grease has a 5 yr shelf life (or more)
Old 03-21-2011, 08:04 PM
1974 911 w/ 83 SC engine
~Max
It sat in the Earth for millions of years, so I'm thinking it can handle a couple more on a shelf.
Old 03-21-2011, 08:05 PM
Brandon-FL's Avatar
Not sure about BP but from the Mobil 1 website five years.
Shelf Life of Unopened Mobil 1 Quarts
Old 03-21-2011, 08:09 PM
NO don't use it......send it to me freight pre-paid and I will get rid of it for you....my pleasure!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-21-2011, 08:22 PM
i've seen additives settle out to the bottom on old dino oil plastic cans
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-21-2011, 09:52 PM
I'd use it...
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 03-22-2011, 05:36 AM
ivangene's Avatar
did they put a date on it somewhere... just because you have had it a year doesnt let you know how long it sat around before you bought it..... no mfg date? all bets are off.... I wouldn't risk it - PM'ing my "ship to" address for ya
Ed M
86' Coupe
Old 03-22-2011, 06:04 AM
Almost Banned Once
sc_rufctr's Avatar
If it's sealed and stored on a shelf in a garage I can't see it ever going off regardless of what's on that Mobile one page.
If you concerned about the additives settling to the bottom just mix it up before opening.
According to the manufactures, another thing you should be concerned about is moisture absorption but even this is BS IMO.
As soon as you get oil up to normal operating temp any moisture in it would evaporate away.
But think about it. Oil and water don't mix so how can oil absorb water?
The combustion bye products and gasoline break down oil so that's why we have to change it at regular intervals.
Moisture builds up on the engine internals. So a good run to get everything nice and hot at least once a week is a good idea.
I'm sure a lot of this is simple marketing hype to sell more oil.
This also reminds me of the fill for life coolant from VW. (G12++)
Apparently you can leave it in your cooling system forever but it can't sit on a shelf for more than 5 years.
- Peter
Old 03-22-2011, 06:29 AM
AutoBahned
RWebb's Avatar
Oil and water are immiscible so the amount of water that a static pool of oil can absorb is low.
Old 03-22-2011, 01:02 PM
French Import
zippy_gg's Avatar
The plastic container itself also has a shelf life and when it reaches that stage we start seeing leaky oil containers, especially in hot climate. It is in years, and varies as technology evolves.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-22-2011, 01:57 PM
80-911SC's Avatar
Recommended oil change for our cars is annually (unless driven alot) so I would figure you can leave it in the engine for a year ... the one year on the shelf couldn't hurt it ....
Old 03-22-2011, 04:59 PM
