-   -   Turn-signal Relay (http://forums.pelicanparts.com/porsche-911-technical-forum/589206-turn-signal-relay.html)
5String43 02-01-2011 01:15 PM
Turn-signal Relay
Hey, can anybody tell me where the turn-signal relay is located on an '82 SC? I think I may have a problem there, as I'm getting the following symptoms:
The blinker indicator in the speedo works as it should;
Or it doesn't work at all;
Or the signal arrows light, but very dimly;
Or the signals both light at the same time, but don't blink.
This just came a few days ago and I haven't messed with the electrics on the car at all.
Thoughts?
Thanks in advance - 5String
gtc 02-01-2011 01:39 PM
IIRC, it's in the front trunk, down in the very back corner near the drivers side hood strut.
ossiblue 02-01-2011 05:17 PM
The relay is located in the trunk, under the cowl, just forward of the gas gauge. Easiest access is to remove the gauge and simply reach through the opening.
hoohhoo22 03-22-2011 05:57 PM
I've got the same problem with my '78.
Did you ever get it fixed?
What was the problem?
thanks
