-   -   DME Relay, why not one? (http://forums.pelicanparts.com/porsche-911-technical-forum/589227-dme-relay-why-not-one.html)
AMSRoadRunner 02-01-2011 03:30 PM
ANOTHER DME relay thread! Sorry.
After, too many hours searching for someone else that tried this I have given up and started a new thread.
The short end of the story:
My '86 911 (generally stock) sat for a couple years (4+?) while I gathered the courage to rebuild the transmission.
Now that she is all better I had a tremendous time getting it started (i.e. might be replacing the starter soon) once started it only, well never mind, the point is I replaced the DME relay and she came alive! No sweat! Drove the piss out of the car for a couple days, (the more I drove it the more everything seemed to start working again, lights, gauges, funky smells dissipating, etc.) Then one day... no start, suspecting my URO (Chinese) relay; I got another one with the same result, ran like a champ for a few days then no start. (specifically, no spark, especially in the AM when it is a bit colder)
So my question is why are there two relays in one? Why not just fabricate a single relay? Once this ice storm from hell clears out and I can get to my garage I intend to make a jumper wire (harness) to bypass the relay (for the time when the DME relay fails somewhere other than my house), but I intend to put a switch on it, and if I have a switch on it why not a relay?
OH! To make sure my car isn't killing the chinese I was going to stick my ammeter on the jumper wires to determine the load of each system(Sears sells a fantastic DC clamp ammeter for ~$50). Anyone else done that? Any ideas what each load should draw?
Thanks for all the advice!
Andrew
Por_sha911 02-01-2011 03:53 PM
Sounds like you are frying your relay. Maybe someone can chime in with what to test. If nothing else, if you know someone close by that has a 911, put your "bad" relay in their car and see if it starts. That would mean you have an intermittent problem rather than bad relays.
AMSRoadRunner 02-01-2011 04:52 PM
On that thought I pulled the relay then I pulled the guts.
http://forums.pelicanparts.com/uploa...1296606223.jpg
It is a known fact that I am pretty horrible at soldering, however this job is pretty despicable
None of the terminals look like they got hot and I wish I knew what this white powdery stuff is.
HA! It appears that one of the arms for the contacts is pretty badly bent....
nesslar 02-01-2011 05:16 PM
Not that it will solve the problem, but the OEM relays are rated at 15 or 20 amps I beleive. I bought mine (2 in fact) rated at 30 amps; tougher, no doubt.
AMSRoadRunner 02-01-2011 05:41 PM
Sucess!
Turns out the arm that that makes the contact was bent so the electromagnet was engaging but not turning the circuit on.
so what did we learn?
Lesson 1: Don't buy crappy parts
Lesson 2: Don't buy crappy Chinese parts
Lesson 3: Don't buy crappy Chinese parts even if they are supposed to work with your car.
nesslar,
so you are using two relays?
nesslar 02-01-2011 05:42 PM
nesslar,
One is a spare............... :)SmileWavy
kidrock 02-01-2011 07:29 PM
I've never had good luck with URO parts....on my P-car or my Land Rover. Pure caca.
DRACO A5OG 02-01-2011 10:37 PM
From memory, as I understand it the DME relay's terminals tend to fracture over time and use causing non-continuity.
I heard and seen people re-flow the terminals/contacts.
Question is with the non-continuity will that cause the relay to over heat, the usual symptoms of a failing relay.
over,
Wil Ferch 02-02-2011 11:57 AM
yes...the soldered contacts break easily over time due to age and vibration....MADE WORSE by Porsche's idiotic design of the terminals being oriented to plug-in sideways....leaving the relay BODY hanging in space ! ( picture in post #3, here, with the relay cover off). Therefore, there is a tremendous moment-arm leveraging of the circuit board.
Solution?....( or at least, "big-help"?)--> place a rubber block under the unsupported relay body such that you take the bending stress ( gravity) off the body and its plug-in connection.
dshepp806 02-02-2011 02:44 PM
Did this on mine,....!!
My DME Relay is changed out before it fails.
Doyle
nesslar 02-02-2011 03:09 PM
Beautiful. That's really good stuff right there. Maybe add a little electrical tape to hold everything in place. For you, Wil and Doyle: http://forums.pelicanparts.com/support/smileys/wat6.gif
