abit off center
cgarr's Avatar
Sealing cam spray bar?
What do you guys use to seal the spray bar when in place? I noticed a lot of oil passes by the spray bar and the casting at the cam bearing oil passages.
______________________
Craig
G2Performance
Old 02-02-2011, 06:16 PM
abit off center
cgarr's Avatar
No Ideas? When I shot oil through the spray bar with the cam installed I got a huge amount of oil passing between the bar and housing. I sealed the bar at each passage through the casting and now get a lot more oil only at the oiling holes! I guess if you ever remove the bar for cleaning it should be resealed?
Craig
G2Performance
Old 02-12-2011, 04:35 PM
Did you take the aluminium plugs out at each journal? What did you use to
seal it there?
andy
Old 02-12-2011, 11:19 PM
