DrCinGa's Avatar
915 cable shifter
I have researched the site and have read plenty regarding the various shifter upgrades. There seems to be 2-3 very good products; ie Wevo, Rennshift, ect. Who has the Patrick Motorsports cable shift system for the 915?
Is this system better/worse? Worth the $300 difference? Im leaning towards the Wevo, but want to cover all my options. Most of the info I can find fits the cable shift systems to 914's.
Dr. Chris
'74 slantnose 3.0
Other non-P toys
Old 02-03-2011, 02:33 PM
Text me.828-230-0788
Joe Bob's Avatar
Go Wevo.....
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 02-03-2011, 02:34 PM
KTL KTL is offline
Schleprock
KTL's Avatar
There's no reason to cable shift the 915 in a 911.. The shifter and rods work just fine. The cable shift setups you see are for converting the 915 trans to fit in another car of your choice- typically a mid engine car (not Porsche 914)
Cable-Shift - Porsche 915
Are you thinking of the 914's side shifter arrangement conversion?
Welcome to Windrush Evolutions - WEVO - Porsche Products
Patrick Motorsports would be the place to look for their own cable shift setup..........
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 02-03-2011, 02:47 PM
DrCinGa's Avatar
I was just wondering if anyone had used any cable shift system. The Patrick setup just came to mind.
I saw one a few years back and was curious.
Looking like the Wevo. Seems to be the favorite by the number of posts speaking highly of it.
So many people cant be wrong.
Dr. Chris
'74 slantnose 3.0
Other non-P toys
Old 02-03-2011, 03:01 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The Wevo shifter has been around a bit longer than the Rennshift. But the Rennshift buyers are very pleased with theirs too. I don't think you can go wrong with either one.
That said, Wevo's reputation is stellar. Hard to overlook that.
I'll be honest that i've been debating either/or for the racecar, but i'm too cheap to pull the trigger.....
Kevin L
Past: '87 Carrera
Old 02-03-2011, 03:05 PM
DrCinGa's Avatar
Well, I really have no choice. I am in Iraq. My friend takes care of all my toys and drives the p-car to work on Fridays. She has complained about the shifting. I was riding with her last time I was home and she missed a gear downshifting. Not her 1st time doing this. It may be a parts car if I dont get the upgrade soon. I will be home in 6 weeks, so perfect time to make the swap...
Dr. Chris
'74 slantnose 3.0
Other non-P toys
Old 02-03-2011, 03:16 PM
sc_rufctr's Avatar
A cable shift would have some advantages.
1. Not affected by worn engine mounts.
2. More scope for custom adjustment. Shift planes are were you want them to be.
3. Once adjusted properly it should feel the same for ever shift.
4. Freedom to move the shifter to anywhere in the car.
... In a RHD car you could mount the shifter on the right side of the seat ala 917.
You could also use a Balsa Wood shift nob as a finishing touch.
Hmmm. I feel a new project coming on
Peter
Old 02-03-2011, 03:20 PM
DrCinGa's Avatar
RHD, RH shift....very interesting.
Dr. Chris
'74 slantnose 3.0
Other non-P toys
Old 02-03-2011, 03:24 PM
sc_rufctr's Avatar
One of the many benefits of living in Aus.
Peter
Old 02-03-2011, 03:30 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Here's my plug for the Rennshift.
While the Wevo reputation is stellar and I know it is a top notch product, I decided to go with the Rennshift because it is very adjustable. You can adjust the shift reduction percentage, which was key for me. I do not like reducing the shift throw on the 915 too much because i feel it accelerates wear on the syncros by rushing the gear change. Rennshift also offers different lengths of shift lever for optimal placement.
Also, don't forget to address the shift bushings and shift coupler. An aftermarket coupler made AS MUCH of a difference in my car as the aftermarket shifter housing.
I am very happy with my 20% reduction and extended handle setup after about 1.5 years.
1981 SC ROW Coupe
Old 02-04-2011, 06:56 AM
Crusty Conservative
silverc4s's Avatar
Anothe vote for Rennshift
I agree with everything Indy said; I installed a Rennshifter, new bushing on rod, and a helicopterjoint type rear coupler all at once. Net result: my 915/3.2 Carrera 73 Targa went from the worst shifting car to the best shifting car I have driven.
All of Indy's reasons are the same for me, and I will add one of my own: Rennshift system is a complete new shifter assembly, while the WEVO is set of well made parts that go into your old shifter housing. The total Rennshift solution is also a work of art if you appreciate fine machinery (no one here like that, right? )
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 02-04-2011, 08:20 AM
kodioneill's Avatar
Could not have said it better. +1 !
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-04-2011, 11:54 AM
