Back Date G50 Car to 915
Hi,
I have found a roller that I am interested in. It is a G50 car. Is it a "bolt-on" solution to convert it to a 915? As always...thanks for any help. |
Checked out
Can't see how that would be a simple "bolt on" thing.
For one thing, the G50 is a hydraulically operated clutch. Therefore, there is no provision for a clutch cable to run through. Anything can be done with enough $$ and work, but I'd think this would take quite a bit of cutting out of parts from a 915 chassis, and welding them onto the G50 chassis. |
From what I can gather, most of the issues with fitting a G50 into a 915 car relate to shortening the G50 so that it fits into the available space without moving the motor too far back, and clears the 915 torsion bar tube. You need a G50 shifter and pedal box as well, of course.
I've heard this described as "almost bolt-in", if you start with an appropriately machined G50 and other conversion parts, including a custom transmission cross-member. In the reverse direction, it's probably much simpler, as you've got all that extra clearance you don't need for the 915.
'77 S with '78 930 power and a few other things. |
Almost Banned Once
Better weight distribution. And the 915 is lighter! It would also make it easier to install a 930 engine and gearbox... Ye Ha, hehehe ![]() If you go ahead be careful not to over extend the CV joints.
- Peter |
I like the 915 because of weight, cost to own and fix. Is this process fairly straight forward, or headache? I would have thought that there would be a few people doing it for racing?
Recreational User
I suspect anyone who wanted a 915 for racing would have started with a 915 car. It seems unlikely one would swap out a G50 for a 915, since everyone seems to covet the G50 these days. Maybe it's been done, but it is most certainly not a simple swap. You'll have to modify the car and probably the transmission as well. Not easy, not cheap.
There is a weight difference, but it's not as substantial as you might think (depends on the 915). Regarding cost to own and fix I think you'd save money with the G50 vs a swap to 915. The cost of the swap might start the G50 and 915 out about even, but the 915 will require maintenance more often. Even though the parts are cheaper the frequency of maintenance, especially if you put power through it, would likely tip the scales in favor of the G50. I'd do the G50 (or find a different roller) if I were you.
A 915 is lighter, but any performance advantage would be more than made up for by the faster/easier shifts of the G50.
dude, keep the G-50. If you want more power in the future you already have a tranny that can handle it.
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
I think someone here has the weights of a G-50 compared to a 915. What is it, less then 50lbs? Hardly worth spending $1000's in fabrication and custom work to put in a.....915??. Cost to own? Thats a new one on me. Racing? Is there problems the heavier, beefier G-50 can't handle over a 915??
I dont know anything about the G50. The 915 can handle a higher hp engines. It may have difficulty with torque. It would not be a good tranny for a high output turbo motor that pours on the torque once the turbos spool. With the increase in torque, there will be a diminished life expectancy.
This is what I like about it; It can be nearly torn down with 13 mm rench. The gearing is changable, parts are reasonable. It is lighter, but I am not sure by how much? I have read one account of 20 lbs, which is not allot. Thanks for the replies. They are informative. |
The G50 is the stronger box.
MBruns for President
from people much more informed than I am. (I keep this for this type of post)
G-50 vs 915 Transmission Quote:
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
JeremyD, that is great information. I have read it several times.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 02-05-2011 at 06:25 AM.. |
