GOM (Grumpy Old Man)
Help re: H4 Headlights
Can someone help identify the type of H4 headlights I have? Pics are below. The back of the headlights (both sides) have two H1 bulbs (high and low?). The driver-side lens has "H4" in the middle but the passenger side does not, although it appears the cutoff in the glass is exactly the same. I tried searching but couldn't find pictures similar to mine, although I'm sure they are out there if I searched long enough. Thanks in advance for your help. Jim
Passenger-side lens ![]() Driver-side lens ![]() Backside of headlight ![]()
Instagram: @3pedalposse |
you have H1 headlights that someone clipped and bodged the adjuster screw flexible cable and then put on an H4 lens on the driver side.
Tru6 Restoration & Design |
Notice that the top of the H1 lens is clear but the H4 lens is frosted. I once actually ground that flat to look like an H1.
1988 Carrera Coupe |
Bottom line, individual parts such as the screws are not available as separate pieces, AFIK. If the adjustment is currently good, leave it. Otherwise, try to hunt down some old H1 assemblies and cannibalize what you need.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 02-07-2011 at 06:17 PM.. |
if the chrome rings on them are very nice, each ring alone is worth $100.
Wash. State
Is this a case where the best solution is to put a H4 lens on the other one too??
In short, the answer is "no."
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Wash. State
All makes good sense; that's why I asked. Thanks.
Thanks for the info, folks. This place is great. Anyone have a spare H1 lens they want to sell?
Instagram: @3pedalposse Last edited by Busta Rib; 02-07-2011 at 08:50 PM.. |
Pelican Parts - Product Information: 1-305-614-010-M14 |
H1 lens
See this?
Edit: get a new one from Pelican, $$ is just a few bucks more.... and the guy can't even spell Porsche. Last edited by tcar; 02-08-2011 at 12:48 PM.. |
abides.
Right now I have H4 lamps on my car with H1 lenses because I dislike the pebbled finish in the top of the H4s. I can see at night. My car hasn't exploded yet. The world still turns.
Graham 1984 Carrera Targa |
Wash. State
Well, if Warren said it... well, you know.... Jesus, a good lens is a good lens. And I find H4 lenses to be awesome, plus I like the "pebble" finish, it probably allows for less light to escape "up", too!
Good post, gtc, IMHO.
Does anyone have a spare set (for one lamp) of these wires which I have circled in yellow ? Including the white plastic terminal piece which is attached to the metal ? (and maybe the brown isulation piece in between - I have to check) . Or that whole metal piece , if it is not possible reattach a white terminal/brown insulation square to one (or I cannot get them loose).
I might need the copper strip also , I have to check. I bought a set awhile ago , and the guy never came up with these pieces on one. If so , PM me. thx
Warren was right. The H1 has a separate bulb for lows and a separate bulb for highs with 2 separate reflectors and 2 separate focal points. As I'm sure you know. Your lows may be fair, but your high pattern will suck. You are correct that your car won't explode and the world will turn, though. Last edited by tcar; 02-09-2011 at 03:15 PM.. |
abides.
Jim,
I'm local and have spare lenses of both types you could borrow to try out and judge for yourself. Send me a PM if you're interested.
